Question about Franke Flair Espresso Machine with MilkMate
How to remove the lid on a franke flair coffee machine
    New Friend:
  • 29 Answers
If you are refering to the main cover! firstly the hoppers have to be removed. then the metal plate on the top(cup warmer) secured with 4 x t15 torx screws. once the plate is removed the main cover is secured with 4 oval headed screws 2 of them located under the plate just removed. the other 2 are located under the adjustment rings for the grinders. the main cover then can be removed. there are 2 electrical connection plugs that have to be disconnected .
Posted on Apr 27, 2015
Testimonial: "Thank you very much will try your advice.one last question what tools do I need to remove the oval screws ?"
SOURCE:
No milk and steam dispensing from Franke Flair coffee machine
I am a Franke technician. After and possibly during the descale, because probably you haven'nt done it in a long time, steam was able to escape through the fittings as the limescale damaged the silicone rings beforehand. The steam damaged the klixxons or the thermoblock itself. You will need one of us unfortunately....
Feb 17, 2018 | Franke Coffee Makers & Espresso Machines
Franke flair will not turn on i opened one of the coffee hubs whilst the machine was on after this it turnt of and now will not turn on i dont no what i could of possibly done i have opened it up to check...
I used to have a Franke Flair in an airport lounge. They are reliable machines. Remove the big electric plug from the outlet. Check the breaker and then plug it back in and switch it on. Make sure the bean hoppers are properly locked into place. The only problems we had with the machine was bean hoppers and the grinder mechanisms.
Dec 03, 2017 | Coffee Makers & Espresso Machines
My franke flair coffee machine will not power up
the two main reasons for this are the on off switch located on the back of the machine is switched off. the other is the flap to the grinders is not correctly fitted. other than this an exporative visit by an engineer may be required. there are two mains fuses situated by the cable inlet behind the rear panel.
Apr 26, 2014 | Franke Flair Espresso Machine with...
Franke flair trips the electric when turned on
It might be good idea to disconnect the coffee valve and switch on machine as it's 230v and might be shorted and tripping and blows fuses.If it is then replace brew valve.
Apr 13, 2014 | Franke Saphira Espresso & Coffee Maker
Franke flair
Where can I buy new seals or a whole new drop tray please
May 15, 2013 | Franke Flair Espresso Machine with...
I have a franke flair coffee machine when you switch it on it reads on the panel please wait and will not complete the switch on. Any help thanks
DESCALING The Saphira has an integrated descaling program. The procedure takes about 60 minutes. Once started, the descaling procedure may not be stopped. • When acid-containing descalers are used, immediately remove any splashes or drops on sensitive surfaces, particularly from natural stone and wood surfaces. Also, take the appropriate safety precautions. • Turn off the Saphira by pressing the "ON/OFF" button. • Press the button "Descale" until an acoustic signal is heard. • Display: EMPTY DRIP TRAY (Fig.1) • Display: INSERT AGENT IN TANK • Display: PRESS DECALCIFYING Dissolve 2 DESCALING tablets completely in 2.5 cups of water in a vessel and pour the mixture into the empty water tank. Place a sufficiently large container under the steam tube and the coffee delivery outlet. • Press the Descale button • Display: UNIT DECALCIFYING • Display: PLEASE WAIT • An acoustic signal is heard. • Display: EMPTY DRIP TRAY (Fig.1) • Display: FILL WATER TANK • Display: PRESS DECALCIFYING • Press the Descale button • Display: UNIT DECALCIFYING • Display: PLEASE WAIT • An acoustic signal is heard. • Display: EMPTY DRIP TRAY • Display: CLEAN CONTACTS
Good Luck Mikey@espressomachineexperts.com
Dec 22, 2010 | Franke Saphira Espresso & Coffee Maker
How can I get different size lattes and cappucinos with my Franke Flair? all it gives me is a shot size serving...
enter programme button.push and hold for 5 secs.machine will show def product. press programme again to confirm.select product comes up on screen.press the product you want to adjust eg espresso.now use the + and - buttons to scroll through the espresso setting. if you want to adjust anything in the settings, you need to press programme. then make the adjustment with the + and- buttons then press enter when finished the actual adjustment .once finished with the espresso and happy press exit button.repeat the process for the next button. you can down load a manual at franke .com
Aug 17, 2010 | Franke Saphira Espresso & Coffee Maker
If you need a Franke trained coffee machine engineer to repair, service or for training, i can be there within 24hours, Email me for any questions great prices! 50mile radius of CV21 3SH
Hi
I have just bought a Franke Flair coffee machine second hand. It looks like new and the seller said it was in good working order - however it does not have the grinder blocker and I think we need one. I wouldn't mind also getting the once over from an expert and then maybe some kind of ongoing contact should we have problems with it. What are your rates?
Jun 15, 2009 | Franke Saphira Espresso & Coffee Maker
Franke Flair Espresso Machine with MilkMate Logo
256 people viewed this question
Top Franke Coffee Makers & Espresso Machines Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
jonathan Hanson
Level 1 Expert
Are you a Franke Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
