If you follow the cable to the engine look at bracket you will see the mechanics of the emergency shut off and look close there will be a white clip with a black wire under it the clip is spring loaded push up on clip the wire comes off clean and reassemble make sure the clip is touching metal when the handle is not held down if not adjust so with handle completely released the metal part of the white clip touches metal there you go have a great day
