Sony Ericsson W200i Cellular Phone Logo
A
Anonymous Posted on Apr 25, 2015
Errors occur in the menu.ml file? menu is unusable!
The menu is unusable!
  • Thomas
    Thomas Oct 12, 2017
    Do you have a set priority of the menu? The next layer of the menu file (after the actualization) should be the meaning field. Try to change that. Or call the service and they can do your essay for you in the form of a scheme.
2 Related Answers
Anonymous
  • 9 Answers
  • Posted on Apr 22, 2008
SOURCE: menu unusable.
try master reset. my camera stuffed up as well i couldnt fix it.
so i simply returned it to where i bought it n they sent it away for no charge.
A
Anonymous
  • Posted on Nov 17, 2010
SOURCE: cuando presiono la tecla de
Debes reprogramar el teléfono. Llévalo a un centro de servicio para que le actualicen el software.
Samsung ml-2550 paper jam1 problem
Carefully check for any paper stuck in the system.
Does the error go away on reboot? or is it constant?
Does the error occur every time you print or just sometimes?
Install
hello
if you need to install the printer , go these links -- drivers, manual and installation guide
prepare your power cable and data transfer cable.
go to the last link, download the driver (at the word FILE, select it and download) for corresponding operating system you have, save on desktop. disconnect the printer from computer, install drivers. Follow instructions and finally reconnect printer to power and to computer. restart computer. printer will function.
http://www.samsung.com/in/support/detail/supportPrdDetail.do?menu=SP08&prd_ia_cd=06011400&prd_mdl_cd=&prd_mdl_name=ML-1610
http://www.samsung.com/in/support/troubleshootingguides/troubleshootingPopup.do?tsg_seq=273&visitfl=Y
please rate my service with 4 thumbs up
2answers
What is error c=44
QuickBooks attempts to change a damaged transaction or record, you may receive a fatal or unexpected error that contains the value C=44. The C= value in the message indicates the type of error the program has encountered. Typical causes include system lockups and power failures while using QuickBooks. To resolve this issue:
  1. In QuickBooks, select the Window menu and select Close All.
  2. Select the File menu and select Utilities >Verify Data.
  3. If the message "Your data has lost integrity" appears, or the error also occurs while running Verify, select the File menu and select Utilities > Rebuild Data.
  4. When the Rebuild utility has completed, run the Verify utility again to ensure that all problems have been corrected (see step 2).
  5. If the error persists after rebuilding, restore a recent backup that does not generate the error.
A error code keeps coming up -69 no music is syncing
As per http://support.apple.com/kb/HT1210 This error occurs when iTunes tries to send files to your iPod, but a file (or files) is unusable (something is wrong with it).
So basically it's because of a corrupted file.
-=/ Daft Tech /=-
160G problem
When you try to sync files to any iPod in iTunes on a Mac or Windows computer, you might see the following -69 error message:
"Attempting to copy to the disk failed. An unknown error occurred (-69)"This error occurs when iTunes tries to send files to your iPod, but a file (or files) is unusable (something is wrong with it).
To figure out which file (or files) is causing the error, update to the latest version of iTunes and then do this:
  1. Control-click (Mac) or right-click (Windows) on your iPod icon in the iTunes Source pane, then choose Sync Songs from the shortcut menu.
  2. Watch the display at the top of the iTunes window while your iPod is being updated. The name of the problematic file should appear in the display right before the error appears.Then remove the bad file from the list of songs to be synced to your iPod:
  3. Select the iPod in the iTunes Source pane.
  4. Click the Settings tab.
  5. Select the "Only sync checked items" checkbox (please note that this checkbox is only available for an iPod configured to update automatically).
  6. Select the appropriate item under Library in the sidebar and find the bad file in the list. (For example, if the file in question was a song you would select Music in the iTunes Source pane. If it were a video you would select Movies or TV Shows in the sidebar.)
  7. Deselect the checkbox next to the file name.
  8. Repeat steps 1 and 2 to update your iPod. If you have multiple problematic files in your iTunes library, you may need to repeat the other steps to remove them too.
To prevent future issues, you should delete the unusable files from your iTunes library, then restore them from a backup or reimport them from a CD.
If you're not able to isolate to any single file or if another iPod works with the same songs, then disconnect any other devices connected to USB or FireWire and try again. If the issue continues, then then try resetting your iPod. If the issue continues, then restore your iPod.
3helpful
2answers
Error-69 with iTunes
Summary When you try to sync files to any iPod in iTunes on a Mac or Windows computer, you might see the following -69 error message:
"Attempting to copy to the disk failed. An unknown error occurred (-69)" Products Affected iTunes, iPod
  2. Watch the display at the top of the iTunes window while your iPod is being updated. The name of the problematic file should appear in the display right before the error appears. Then remove the bad file from the list of songs to be synced to your iPod.
Cyber kaka
PROFILES icon missing and an ERROR message is shown at start up
try giving the restore factory settings option(or reset option) ....
(it will ask for the security code or password) ...
after giving this all of your problem will be solved ...
there is very less chance if you still persist any problem then just may use of warranty as it is new one .....
any doubts reply me
i am always here to assist you
thank you
bye
Menu unusable.
Top Sony Ericsson Cell Phones Experts
Sean Wright
Sean Wright
Kolbrun...
ZJ Limited
ZJ Limited
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
