Garden Logo
P
Pam kirk Posted on Apr 25, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lawnmower runs but has no drive ? - Garden
John Trigg
Level 2:
Sergeant:
  • Expert 250 Answers
  • Posted on Apr 25, 2015
John Trigg
Expert
Level 2:
Sergeant:
Answers
250
Questions
Helped
61656
Points
746
Sounds like you have a broken drive belt
2answers
Lawnmower will not move while running
no ibfo generic answer --check drive belt --popped off --broke--pulley problem--trans axle problem ---key way on wheel sxle damaged or missing
Sep 25, 2023 • Garden
What is the drive belt diagram for a model 616 grasshopper lawnmower
check the deck carefully it might be written on the right side
Sep 18, 2014 • Garden
1helpful
Cub Cadet 1525 belt diagram
Attached is the blade diagram for correct placement of the deck belt. There is some bleed through from the back page, but you can see the direction of the belt. I have a 1525 mower for the last 11 years, still running and going. Hope this helps! 25105582-ergctme4kokczpvvmmku3zkh-5-1.jpg
Lawnmower wheels won't drive
If its a riding mower it probably the drive belts off track or slung off. The mower will still start up and turn blades with the drive belt off, but want engage to go forward or reverse if this is the problem.
Aug 17, 2013 • Garden
Lawnmower wont start after running then stopped for short period
It should be. The fuel line is under the tank and runs to the carburetor. Make sure you use the fuel shut off, if you have one, or drain gas before you play with the line. Once you find the line disconnect it from the carb and drain any remaining fuel. Then clean with a pipe cleaner and reattach. That should help.
Motor runs fine but can't go foward or backwards on Murray 8hp rear engine riding lawnmower
check the drive belt it might have broke or fell off a pulley
Apr 27, 2012 • Garden
2answers
I need the size of the poly v belt for a qualcast 4000 lawnmower.
Most time you don't have to get original parts like belts from the manufacturer. Suggest you go to a reputable lawn and tractor supply store where they can easily measure the belt and give you a comparable one for your machine. Hope this helps!
Top Garden Experts
Jay Finke
Jay Finke
john h
