If the error goes when you remove the embroidery unit is is likely to be a positioning error when the machine is lost to where the needle is in position to the frame.
What is wrong with my machine when this appears on the screen "stepping motor error"?
The stepping motor feeds the material through the foot of the machine.
It appears that you have an issue with this motor.
You can check the machine, oil and clean the machine to see if this helps.
What is wrong with my machine when this appears on the screen "stepping motor error"? The stepping motor feeds the material through the foot of the machine. It appears that you have an issue with this motor. You can check the machine, oil and clean the machine to see if this helps.
The stepper motor or motors control the needle position. If one is reporting an error that just unplugging the machine and leaving it off for 15 minutes won't fix, it's time for a repair shop.
E1 means it out of order--something in the electronics is mess up--it needs to be serviced
by a service tech with the tools to check the electronics of the machine
I had the same problem. It was plug ed into an extension cord as soon as i plug-ed it into the wall socket presto it works. I sure hope your problem is this easy.
