Fitbit One Activity Tracker, Burgundy Logo
K
Karen Posted on Apr 23, 2015
How do I set the time on my Fitbit One - Fitbit One Activity Tracker, Burgundy
How do I reset the time on my fitbitcharge 2
Make sure the time zone setting is correct by following these steps:
  1. From the Fitbit app dashboard, tap the Account icon.
  2. Tap Advanced Settings.
  3. Under Time Zone, turn off the Set Automatically option.
  4. Tap Time Zone and select the correct time zone.
  5. Sync your tracker.
How do I fix the time on my Fitbit device?
  1. From the Fitbit app dashboard, tap the Account icon. > Advanced Settings.
  2. Tap Time Zone.
  3. Turn off the Auto option and select the correct time zone.
  4. Sync your Fitbit device.
https://help.fitbit.com/articles/en_US/Help_article/1176
Manual for Alta Fitbit How do I set the time and date for my fitbit
You set the date and time from the Fitbit App or Fitbit Connect when you setup or sync the fitness band with the computer/tablet. Open the Fitbit Dashboard and then tap (or click) the Account icon. Enter the Advanced Settings menu and check the Time Zone section. If needed, turn off the Automatic option and manually set the current time zone. The Alta will display the date and time based on the time on your computer/tablet when you synced the devices. See https://help.fitbit.com/articles/en_US/Help_article/1176/?q=set+date+amd+time&l=en_US&fs=Search&pn=2 . This is the "How do I change the time on my Fitbit device" FAQ.
Alta has the manual for the Fitbit on the product support page: https://help.fitbit.com/?p=alta . The direct link to the manual is https://staticcs.fitbit.com/content/assets/help/manuals/manual_alta_en_US.pdf . Additional device help is available at the help page: https://help.fitbit.com/ .
I hope this helps.
2answers
Just received my fitbit blaze and I don't know how to set it up
Fitbit Setup
Note that only setting the time zone can be done manually. The specific time is derived by syncing with the primary device, not the fitbit.
I can't find my instructions. how do I correct the time on my fitbit charge?
    1. Editing your timezone settings
      1. Log into your dashboard at fitbit.com and click the gear icon in the upper right corner of your dashboard.
      2. Choose Settings > Personal Info and find the Time section.
      3. Choose your timezone and select your 12-hour or 24-hour display preference.
      More items...
      Help article: How do I update my Fitbit settings? - Fitbit Help
      https://help.fitbit.com/articles/en.../How-do-I-update-my-Fitbit-settings Fitbit
    Feedback
  1. The time is incorrect on my tracker's display - Fitbit Help
    https://help.fitbit.com/.../The-time-is-incorrect-on-my-tracker-s-disp...
    Fitbit
The time on my fitbit is incorrect. How do I correct. Currently it registers 9:43, but, I'm on Eastern Standard Time.
    1. Editing your timezone settings. Log into your dashboard at fitbit.com and click the gear icon in the upper right corner of your dashboard. Choose Settings > Personal Info and find the Time section. Choose your timezone and select your 12-hour or 24-hour display preference.Mar 10, 2015
    Feedback
2answers
How to set time on fitbit?
Top Fitbit Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Fitbit Tool and Hardware - Other Expert? Answer questions, earn points and help others
