Now the red light blinks 5 time while watching it. Is there any way of ..... 2006 that willnot power on and the green LED is blinking 6 times. We had a service ...
Mar 17, 2012 - 14 posts - 4 authors
We have had a Sony KDF E55A20 since January 2006 and it has been trouble free. ...The TV will switch on fine green power lights. Then after about 20 ... If I turn off and turn on the power light will flash red 5 times. Leave it off ...
? 3:36
https://www.youtube.com/watch?v=BLkyFXv2-i4
Apr 6, 2012 - Uploaded by SonyListens
Sony TV - How to troubleshoot a red or blinking light ... and power lights, these easy steps will help you determine what the... 5:17. Easiest TV repair - How to Fix Power [TV turns off, freezes, ... Get video URL at current time.
Does the front light stays green ? Or goes back to red ? The back-light going on/off maybe the problem, but it shoul return with a red blinking led (4 times ?) and if so it can be a power inverter problem.
KDL- Bravia blink codes (Australian): 2 times-Main power supply voltage error (12V, etc) 3 times-Malfunction of 3.3V line 4 times-Malfunction of 5V line (Voltage Supply to FE, etc) 5 times-Malfunction of power supply for screen 6 times-Malfunction of inverter or overcurrent, etc 7 times-Abnormal temperature inside unit 8 times-Audio circuit error (amplifier, etc.) 9 times-Fan malfunction 10 times- Digital FE circuit error 11 times-Malfunction of Trident IC or around IC 12 times-BH board error 13 times -Malfunction of balancer If this is correct the 5 blinks is the power supply having problems, I would much rather change the PS than replace the screen. Also if screen is determine bad, look for class action lawsuit on Sony for defective screen, i am told they know all about this.
Diagnosis item
TIMER/STANDBY
Indicater
Number of blinks
Supposed malfunction Condition
Self-diagnosis
screen display,
Diagnosis item: Results
•Power not ON 0
[Standby Power Supply System]
F601 open.
R607 open.
Q601 short circuit
[Main Power Supply System]
IC601 and R612 are broken.
VDR601 short-circuit
Cannot turn on the power.
LED doesn't blink.
+B OCP detection 2times Short circuit of power supply system in each circuit.
Goes to the standby mode
Short circuit of +B line
2 : +B OCP 000
+B OVP detection 3 times
T603 pin 78 open.
R672 open.
Malfunction of power supply circuit
3 : +B OVP 000
Vertical deflection stop 4 times
IC1509(V out) is broken.
Q1505(V Pulse Buffer) is broken.
Raster goes to one line horizontally, Aand then video
signal is muted.
4 : V Stop 000
Video out abnormality detection 5 times
Video out, Q705, 732, 761 and others in C board
circuit.
Q218, 219, 220 (A board)
TIMER/STANDBY LED blinks approx. 30 seconds,
and then blinks for the self diagnosis.
5 : AKB 000
Horizontal deflection stop 6 times
C515, 516 open.
IC206(YC Jungle) is broken.
Raster doesn't appear. 6 : H Stop 000
Audio abnormality detection 8 times
IC406(Audio amp.) is broken.
PS401, 402 open.
The sound is not out.
8 : Audio 000
Hi, Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number... A1085447A* LAMP BLOCK ASSY XL-2200U It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
I get 5 blinking red lights for about a minute or so before it powers back down. The Sony TV has a specific light that i presume is supposed to light up when the bulb is out. I'm unsure if this is what it is. no picture, no sound. tries to boot with green light blinking a few times. then goes to red blinking light, six in all, then waits a few moments, then another 6 blinking red light.
Bulb was already replaced several months ago but we do have the TV on for long periods of time.
i also have the same problem with the flashing green light for a while then a different red light starts blinking on and off around 5 times....and i replaced my burnt bulb with a new one...still no picture.
