What does it mean when I get internal administrator locked?
After I ran HP Recovery I no longer can sign in as administrator, only as guest. All I get is see administrator. What do I have to do see administrator . Where can I find administrator settings?
Hello Friend.!! You can BYPASS Administrator Login using this Video https://www.youtube.com/watch?v=06r9DkMMafY
There are Tools/Utilities like KONBOOT that can bypass login but must be made BOOTABLE using RUFUS Software
Question: How do I bypass a Windows 7 account password if the only account I can access is guest? Can I <a href="http://www.windowspasswordsrecovery.com/">bypass Windows 7 password</a>
with the guest account? I forgot my Windows 7 administrator password,
how can I regain access to my computer without the password? I have no
Windows password reset disk.<br />
<br />
Recently I met many similar questions. Are you troubled with the same
problem, also forgot Windows 7 password? Well, before answering the
question, you should understand what a guest account is?<br />
<br />
<span style="font-weight: bold;">What is a guest account in your Windows 7?</span><br />
<br />
The guest account in your Windows 7 only allows people to use your
computer without having access to your personal files. With the guest
account, you can't install any software or hardware, change settings, or
create a password. Because the guest account allows a user to log on to
a network, browse the Internet, and shut down the computer, you should
disable the guest account when it isn't being used.<br />
<br />
Solution: After learning the definition of a guest account, you can understand it is not possible for you to <a href="http://www.windowspasswordsrecovery.com/">bypass Windows 7 user password </a>through
the guest account. But you can bypass your Windows 7 password, with
Windows Password Recovery Tool 3.0, a safe and efficient tool for you to
bypass Windows 7 password. It allows you to bypass your lost Windows 7
password in less than 5 minutes.<br />
<br />
<span style="font-weight: bold;">What is Windows Password Recovery Tool 3.0?</span><br />
<br />
Windows Password Recovery Tool 3.0 is professional Windows password
reset software with 3 editions: Windows Password Recovery Tool 3.0
Standard, Windows Password Recovery Tool 3.0 Professional and Windows
Password Recovery Tool 3.0 Enterprise.<br />
<br />
It is designed to bypass Windows domain password, Windows administrator
password and user password. With this Windows password recovery tool,
you can instantly regain access to your locked computer by burning a
bootable CD/DVD or USB flash drive on your own. No need to reinstall
computer or pay to PC experts when you forgot administrator password or
domain password on Windows 7/Vista/XP/NT and Windows Server
2008(R2)/2003(R2)/2000.<br />
<br style="font-weight: bold;" />
<span style="font-weight: bold;">How to <a href="http://www.windowspasswordsrecovery.com/">bypass Windows 7 password</a> easily?</span><br />
<br />
Step 1: Download and install Windows Password Recovery Tool 3.0 Professional.<br />
<br />
Step 2: Burn bootable CD/DVD or USB flash drive.<br />
<br />
Step 3: Set your locked computer to boot from CD ROM or USB.<br />
<br />
Step 4: Choose the installation path of Windows, and enter the ID of the path.<br />
<br />
Step 5: All Windows account user names will be displayed for you. Enter
the ID of a specified User Name to remove its account password.<br />
<br />
Step 6: Enter y to confirm and continue your operation.<br />
<br />
Step 7: Enter y to remove another Windows account password or enter n to
finish your operation when the selected windows account password is
removed.<br />
<br />
Step 8: Take the burned USB flash drive out of computer and press any
key to restart your computer when you enter n to finish your operation.<br />
<br />
The Windows 7 administrator password has been successfully reset and now
you can access your computer without password. Please note this method
to bypass Windows 7 password takes effect only when you log on computer
after <a href="http://www.windows7password.net/"><span style="font-weight: bold;">Windows 7 password reset</span></a>.
Know how to reset windows 7 password, you can refer to this article: How to reset Lost Windows 7 password, it tells you how to reset Windows 7 password with special method within 5 minutes.You also can use Daos Windows 7 Password Recovery Tool to add a new user with administrator privilege to your Windows. With this New user account you can and logon your locked computer directly. http://www.daossoft.com/windows-7-password-recovery/how-to-use-windows-7-password-recovery-tool.html
is this the password to log into the computer, password for BIOS or Power on passwords......
if power on passwords or BIOS passwords, remove CMOS battery and leave it out for 30 minutes then slot it back, that will reset all passwords and set all system to defaults
if log in password, click on ctrl+alt+del twice then type in administrator on the username and press enter....
STEPS
username:Administrator, password:blank (do not type anything). then press enter.
go to control panel then select Administrative Tool
click on Computer Management
Click on Local USers & Groups
Click on Users
Right-click on your username on the right pane then select SET PASSWORD
Try logging in as administrator in safe mode if you have not tried that already. Some of the newer spyware/malware has been disabling admin accounts and wiping out recovery points. I battled some spyware last week like that.
When you get into safe mode are you only getting in as a guest or are you able to get in as another user?
Let us know how it goes.
Sorry, Marie, didn't quite get the whole problem. Try a reboot. If that doesn't work, try safe mode. You get to safe mode by rebooting, then when the Mfg splash screen comes up (ie HP/Compaq/Presario) hit F8 until you get the dos menu. The DOS menu is a black screen with about 8 options or so. Use your arrow keys to highlight Safe Mode. Again try to get the Administrator account open by choosing that account and then just hitting enter. If you get in, open the Control Panel, then the User Accounts. Then either change the logon procedure using options or remove the password from the user account you're having problems with. If you can't get this far, you probably have a virus and should submit your computer to a professional for backup and recovery of the hard drive.
You might get in using "Safe Mode" and going throught the Administrator account. If you have no password on that one (most people don't) then all you need to do is hit enter. If you have the same account listed on your Welcome page try it there first. If not Google password recovery. There are some free password recovery programs online that could help. Only other choice is to have your documents backed up by pulling the HDD then do a full recovery using the recovery partition or CD.
