Question about Maytag EPIC MFW9600S
No alarm only the door close after i have flash light and dont start
    Genius:
  • Maytag Master
  • 1,585 Answers
Probly door inter lock
Posted on Apr 26, 2015
SOURCE:
Hotpoint FZFM171 freezer door left open all night, has defrosted and the 'super freeze' light and alarm light wont stop flashing. How do we fix it?
Turn the power off to the refrigerator and manually defrost the freezer until the freezer bis no longer cold and then replug the power cord
.APPLIANCE 911
Jan 27, 2016 | Hotpoint Refrigerators
How can desactivate my alarm in my 99 montero?
Try pressing the lock button on your door then close the door then use your key to get back in, not the remote. If that doesn't work then close all doors,turn your key 1/4 towards ignition,press and hold the flashing red alarm light for 5 seconds and this should disarm the system and allow you to start the vehicle.
Not knowing exactly which vehicle you have this is all I can think of. Hope it helps.
Nov 22, 2012 | Cars & Trucks
My led light for my alarm stays on and the alarm dont work anymore but the button still locks?unlocks/and starts
Your system is in valet. To take the system out of valet with remote: open any door, press lock, unlock, lock. Now check the LED; it should be off. Close the door and arm the system to check.
OR
Turn the key on then off. Within ten seconds press and release the valet switch. The LED should be off now. Close the door and arm the system. The alarm should chirp to confirm that it is armed.
Nov 26, 2010 | Remote Start System
Start light flashing. Unable to adjust
water not entering machine start light flashing and alarm sounds
Nov 13, 2010 | Tecnik TDW2677 Built-in Dishwasher
Alarm keeps sounding and blue light is flashing on dash board, if I close the door the alarm starts all over again. The alarm sounds very weak and weird. Car won't start,
This may sound silly but it worked for me. Try sticking the key in the drivers side door with the alarm going off and go through the motion of unlocking the door. Good luck.
If I have helped you resolve your problem, please
consider giving me a good rating. Thank you.
Oct 22, 2010 | 2004 Mitsubishi Galant
Car doesnt start immeditately. security light comes on. once security light goes out car starts. Why?
it is detecting a problem....could be a dirty key or bad chip in the key....try this.....set the alarm by locking the door using the power lock switch and then close the door...the security light should come on steady for about 2 minutes and then go out.....the alarm is armed at this point.....you can unlock the drivers door using the key to reset the alarm.....if you do this with the windows down you can open the door from the inside to set the alarm off and see if it works properly by flashing lights and horn....after you trigger the alarm you will have to reset it by using the key on the drivers door....
Jul 04, 2009 | 1998 Buick Riviera
Electrical
Go inside the vehicle,dont put key in ignition, leave driver's door open, press the auto lock button on the driver's door, now close door while you are inside and watch on the dash the alarm enable itself, once it stops flashing open the door, this will set off the alarm, lights flashing horn blowing. Now take the key and put it in the drivers door and turn the key to stop the alarm. Now start you vehicle. If you want you can take the glove box apart to get to the vehicle security module to remove it. Dont unplug it unless the vehicle is running (must be running due to back up on computer) unplug the module and you will never have another problem with the security again and it does not effect your powerlocks.
Jul 09, 2008 | 1995 Jeep Cherokee
Jeep alarm will not turn off
The ignition security on/off is located at the trunk lock. unlock and lock rear gate and the alarm will turn off. My jeep sat in my drive for a month before a jeep tech told me this. It still triggers the security sometimes when I unlock the passenger door with the key and I go straight to the rear gate lock and it shuts off instantly.
Jun 27, 2008 | 1994 Jeep Grand Cherokee
Maytag EPIC MFW9600S Logo
32 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
