The not coffee does not stay hot
I called Cuisinarts repair center and they had me set my auto off button. It had been set to 0 so it shut off as soon as it started brewing. If you turn the switch to auto off, then when the numbers are blinking hit the hour button until you get the desired hours you want the heating element to stay on. Then when you stop hitting it it will remain at that time after you brew your coffee. If that doesn't work you can call the help line at 800-726-0190, just give them your model number and serial number, the device carries a 3 year warentee
Most likely you have a heating eleament down and will need to replace it.
the coffee pot warmer is not working
The warmer does not keep the coffee hot and it is less than a year old
Had the pot only a couple months. The warmer is on when the pot is brewing then then once it beeps to indicate brewing is complete, the light shuts off and the warmer won't stay on.
pot brews coffee fine. when thru brewing cycle pot beeps and shuts off.
Yes, grind is fine but warmer does not work.
I have the same problem
