Tip broke off? A single bar slide tube? Head to Ebay and buy a STRAIGHT WALL double bar slide tube. It'll run you approx $25. If your gun is an older single bar, it'll have the spring thingies on the mag tube. Those are standoff bushings meant to keep the slide tube from rubbing the mag tube in more than a few small areas. Stops rubs and friction. You'll need a two bar STRAIGHT WALL slide tube to work with those bushings. Newer slide tubes have dimples that will NOT work with those bushings. When you get the two bar straight wall tube, just pop the pin out of the one bar and you'll have a new tube. If you want to get rid of those bushings so you can use a modern dimpled tube and forearm, buy a new mag tube without the bushings, and a two bar dimpled slide tube.
