Question about Pride New Mobility Victory XL 4 Wheel Scooter
Having trouble with a 3-wheel Pride Mobility Victory scooter. When throttle is applied does not move.
  • 175 Answers
Check that it is unplugged from the charger. Then check the freewheel lever to ensure it is in gear by placing it out of gear first, then placing it firmly in gear. Do this while the key is OFF. Wait three seconds, then turn back on and it should go.
If it doesn't, and you are sure it's in gear and unplugged from the charger, you should be getting a fault code flashing on the charger display. Consult your owners manual to determine the fault and proceed as recommended.
Here's a link to the owners manual if you've lost yours. Good luck.
http://www.pridemobility.com/pdf/Owners_Manuals/US_Scooter/US_Victory_om.pdf
Posted on Jul 11, 2009
SOURCE:
Scooter is saying error code 8 which is motor does anyone know what this could be please?
Pride Mobility Products Victory 9 Scooter 4 Wheel Error code
www.fixya.com > ... > Pride Mobility Products Victory 9 Scooter 4 Wheel
Pride Mobility Products Victory 9 Scooter 4 Wheel, error code related issues. ... Question about Thermometer Mobility Scooters ... error code is 8 Error code 8 means an internal controller error or problem and requires replacement of the controller. ... Theysay there is no listing for code 9 I have replaced the batteries,checked .
Basic Troubleshooting Instructions - Pride Mobility Productswww.pridemobility.com > Resource CenterPride MobilityScooters. INFINFB2040 Sonic Troubleshooting ... Chargers. INFINFB2586 Charger Indicator Codes ... Disclosure Statement Pursuant to Cal. Civ. Code 1714.43(a)[PDF]Legend Owner's Manual - Pride Mobility Products
Nov 28, 2015 | Pride Health & Beauty
I REPLACED THE THROTTLE CONTROL ON MY PRIDE V10 SCOOTER AND RIDING IN GRASS IT STOPS AND BEEP 6 TIMES
6 beeps =
Throttle lever (pot) is not in center position. Return throttle lever
to center position, then turn scooter OFF then ON.
Mar 07, 2015 | Pride Victory 10 3-Wheel
What does the 7 beep code mean on my Pride Victory 10 scooter mean when I turn the key on ?
This is a speed pot or throttle control problem (wig-wag) have you had some speed issues with the scooter before this happened, if so the wig-wag needs replacing. Make sure it is in the centre position at rest and switch the scooter on again.
Jul 11, 2014 | Pride Mobility Products Pride Victory 10 -...
My victory scooter will not go foward
if the throttle pot feels okay that is what the lever is attached to ? is it loose ? if it goes in reserve okay i would say it's the throttle pot, i can get you one of these if required.
Dec 06, 2012 | Pride Mobility Products Pride Mobility...
1997 PRIDE VICTORY GIVEN TO ME, BUT NEEDED FRESH BATTERIES PURCHASED NEW BATTERIES INSTALLED THE KEY, LITES & HORN WORK BUT UNIT WILL NOT MOVE FORWARD AND/OR BACK
check the freewheel lever on th rear of the chair near the right rear wheel if you can push the scooter easily then you are in freewheel locate the lever and move it to the drive mode and try to drive the scooter again if it still won't move then you have other problems that can only be checked by a service tech Hope this helps
Feb 26, 2011 | Pride Mobility Products Pride Mobility...
Could you please tell me where i will get forward& reverse throttle for pride victory
Throttle potentiometers are a frequent part that is replaced on scooters due to wear. This part is available from the manufacturer Pride or from a company called Monsterscooterparts.com.
At the Monsterscooterparts home page click on mobility scooter parts, pride scooters, pride parts click on Pride Victory XL SC270 , select throttle pot assembly. Verify SN and compatibility remarks. They have an 800 phone number for questions and they ship worldwide. The Pride part number is ELEASMB 1511 for Victory XL 4 wheel scooters after the year 2000. Looks like the price is about $80. Labor is about 1/2 hour and can be done by an experienced mechanic or do-it-yourself. The part is available from the manufacturer if you are a dealer or have an account.
First remove the throttle lever by loosening the allen set screws. Separate the front console covers by removing 8 or more screws holding it together. Locate the throttle pot, unplug it and install a new one. Be careful not to over-tighten or strip the screws holding the potentiometer housing tabs to the plastic. Check the alignment visually before reassembling it. Don't pinch any wiring when you put the console back together. When you reinstall the throttle lever make sure it is even left to right and does not bind on the plastic console housing. Tighten the lever set screws firmly but do not strip them, this repair will need to be done again and you want to be able to remove these set screws. Hope this helps.
Nov 07, 2010 | Pride New Mobility Victory XL 4 Wheel...
My Pride Legend 3 wheel scooter will not go forward. It goes in reverse with no problem. Help
Hi, sounds like the speed pot that is attachment to the throttle lever is worn and needs replacing, this is normally a 5K pot,
Regards
GeWiz.
Feb 13, 2010 | Pride Mobility Victory 3 Wheel Electric...
I have a pride scooter that will not run at top speed. When speed control is turned to fastest setting, the scooter goes dead.
hi, first check the speed throttle by moving it in the upwards direction while the speed control is turned fully on, if there is a response to moving the speed pot in up and down direction , you founf the fault, otherwise the speed control is at fault, if thats proves to be okay then its the controller breaking down , check the brushes on the motor.
regards
GeWiz
Oct 30, 2009 | Pride Mobility Victory 3 Wheel Electric...
I have a pride victory scooter and at low speeds it shutters and gets worse when it gets hot and worse in reverse..
that could be the speed pot , try moving the throttle lever upwards to see whether it stops shuttering, if not check the motor brushes.
Regards
GeWiz.
Oct 04, 2009 | Pride Mobility Victory 3 Wheel Electric...
Goes in reverse but not forward
hi, that sounds like the scooter
a. the speed pot is faulty (Wig wam) thumb throttle , check just in case there a reverse switch,
b. been taking apart and reassembled incorrectly.
Regards
GeWiz.
Jul 03, 2009 | Pride Mobility Victory 3 Wheel Electric...
Pride New Mobility Victory XL 4 Wheel Scooter Logo
279 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
