Question about Samsung Side By Side Refrigerator - RS25H5111SR/AA
My brand new Samsung side-by-side refrigerator RS25H121/RS25H5111 (purchased 4-14-2015 is driving us crazy with the humming noise. What can we do to greatly reduce this loud hum?
Purchased 4-13-2015. refrigerator is noisier than the seven year old LG refrigerator we were trying to replace (also due to humming)
    Genius:
  • Samsung Master
  • 1,585 Answers
Get it replaced don't wait faulty compressour
Posted on Apr 21, 2015
SOURCE:
SOURCE: Samsung Side by Side Refrigerator RS2556SH - Making loud noise
Hi, had the same problem with my RS21DCNS engineer came and made a modification to drain hole (made the hole bigger!) this allows for a little more ice to form without causing the horrid noise. A new backplate was ordered as all new models have a larger hole in the backplate already. It only takes a few mins and it under guarantee if you bought less than 2 yrs ago, but you will have to empty fridge side to allow them to get to inside at the back. Good luck.
Posted on Oct 19, 2006
  • 22 Answers
SOURCE: Samsung Refrigerator
this is a design fault on the appliance normally caused by the failure of the element and built up of ice around the circulating fan (the humming is the fan motor trying to turn ) youll find that if you defrost it it will work for a little while and then ice up again the need to replace a panel inside the fridge modified and a couple of sensors and poss the heater element
Posted on Nov 13, 2008
tborn6
  • 700 Answers
SOURCE: Samsung RF267AABP Noise problem
it sounds like the unit is in defrost. the noise is the souind of the ice breaking up. also you might be able to increase your ice produsction by setting the ice sensor to 17.5 degrees from the current 0 degrees
Posted on Mar 06, 2009
  • 59 Answers
This unit has a history of problems on the refrigerator side. the basic reset is press and hold down the 2 middle buttons on the freezer at the same time. As a general rule the number one problem is in the mother board. usually you can replace it and everything will work.
David
Posted on May 22, 2009
SOURCE: noise (more detail)
I think I answered this in an earlier post.
The noise is the fan banging against the motor housing. It's not a defective motor, it's a poorly designed motor.
The solution is to shim the motor mount so it is slightly out of level which will keep the fan from bouncing off the motor housing.
The reason Samsung won't service is they don't understand the problem. I've seen this a half-dozen times.
Trust me -- SHIM THE MOTOR MOUNT!
Posted on May 27, 2009
Samsung RS25H5111 ice maker in the door. Cube ejector arm gets stuck when it tries to eject frozen cubes.
There is a heater on ice maker that thaws the cubes to make them slide out of the tray easier. Check the temperature of the freezer and see how cold it is set to. If you can make it a little bit warmer that might help.
Jul 02, 2016 | Samsung 24.5 cu. ft. Side by Side...
Freezer side is making an extremely loud humming sound. Ice maker is working fine. No ice buildup anywhere in the freezer that we can see. Loud humming goes on for a few minutes each hour.
Hey Joanne, I appreciate your inquiry!
Based off my understanding the freezer side of your Frigidaire refrigerator is making a loud humming noise. The humming sound could be coming from your compressor. If the sound is a new development it may be a possible issue with the fan pushing further against the wall. You may need to seek help from a professional technician for proper diagnosis and repair. This will help you from purchasing any unnecessary parts. Hope this information is helpful to you. -Matt
Dec 30, 2015 | Frigidaire FRS23W3A Side by Side...
Why would a brand new fridge make strange noises already?
Good Afternoon Friend,
I understand that your Frigidaire refrigerator, model# FFSS2614QS, is making a strange humming noise. Your new, high-efficiency refrigerator may introduce unfamiliar sounds. These sounds normally indicate your refrigerator is operating correctly. Some surfaces on floors, walls, and kitchen cabinets may make these sounds more noticeable. This could possibly be the compressor that you are hearing. Modern, high-efficiency compressors run much faster than in the past. The compressor may have a high-pitched hum or pulsating sound. Hope this is helpful.
-Best Regards-
WP
Jul 02, 2014 | Frigidaire FFSS2614QS FFSS2614QS 26 Cu....
Rs25h5000 samsung refrigerator
Horrible fridge..support say they are techs..different answer every time..do not kniw what they are doing..Gone downhill
May 24, 2014 | Samsung RS2530B Side by Side Refrigerator
Freezer Humming. Making me Crazy.
the fan motor is probably going bad.its about a $50.00 part and its behind the back wall,grab the model number and go to an appliance parts store and order or pick one up.
Apr 25, 2009 | GE GSH25JFR Side by Side Refrigerator
Noise & icing
sonds like thre is a problem with the defrost because you should not have that much ice on the coils. go ahead and do a manual derfost and make sure that the drain lne is clear and not frozen up. If it is oyu can use a turkey baster with hot water to thaw it until the watr flows easily out the tube in the unit. also how are you gaskets looking? are they starting to leak air into the freezer and the refrigerator/ at 18 years old those are a few of the things to look at. Hopte that htis solves yur problems and if not don't rate this and I can still come back and post answer or solutions for yu. After the final them rate if you would be so kind. Thanks for using FixYa.
Jun 04, 2008 | Samsung RS2630WW Side by Side Refrigerator
GE GSS25SGRE
It is not the freon:
http://www.selfhelpforums.com/archive/index.php/t-11409.html
Jan 21, 2008 | GE GSS25SGSSS Stainless Steel Side by Side...
Samsung Side By Side Refrigerator - RS25H5111SR/AA Logo
554 people viewed this question
Top Samsung Refrigerators Experts
Paul
Gerry Harvey
Gerry Harvey
jasbo
jasbo
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
