Coffee Makers & Espresso Machines Logo
N
Nicole Grimes Posted on Apr 20, 2015
Machine says "Solvent in tank open tap" How do I fix this?
Karen Maguigan-Purcell
Level 1:
  • Contributor 3 Answers
  • Posted on Apr 21, 2015
Contributor
Level 1:
Answers
Questions
Helped
520
Points
11
You really don't give which machine - but here is link to company product support. Maybe they will have product manual to help trouble shoot issue. Sorry could not of been more help
Product Support
2answers
How to drain all water in the house
Turn off the main supply to the house open all the taps ( turn off gas to heating and hot water ) Drain heating and hot water side if it s a wet system .Flush all toilets remove water from toilet pans . Open any outside taps .
tip
No Steam, No Water? Quick Fix
All of a sudden I had no steam and no water.
I could hear the pump chugging and trying hard, but nothing came out of the nozzle.
First, check to see if the nozzle is blocked. If it's not, try turning on the tap (faucet) and PUSH IT IN towards the machine.
If you now get steam and water, there is a quick fix.
Switch off the mains, unplug the coffee machine and take all normal precautions not to electrocute yourself.
There is a small cam on the (Part 9161205 - Faucet rod stem) which pulls the tap IN as it is opened and OUT as it is closed.
1] Remove the coffee container - there are two phillips screws only, and it lifts off.
2] Remove the top casing. There are two phillips screws either side at the front top, hidden by the door, one star head screw under the water tank, and one normal phillips screw under the water tank in a deep channel.
3] Take a look at the small cam on (Part 9161205 - Faucet rod stem) and see if it moves in and out as you turn the water/steam tap on and off. If it doesn't the plastic has sheared off. If it does move in and out - this is not the fix for you!
4] If it does NOT move in and out as you turn the water/steam tap on and off, find a small self-tapping screw and screw through the angled cam hole into the faucet rod stem. Pop the top casing and the coffee container back on and your machine is now fixed!
Now for a delicious cappuccino62e2053.gif!
1helpful
2answers
Why does my water container fill up even though my machine is plumbed in?
This looks like a fault. The plastic tank has two reed switches that measure 'tank empty' and 'tank half full'. When the tank is empty the inlet solenoids (there are 2 for safety) open and water enters the tank but not so much to fill the tank to the half way level. In normal operation the level water in the tank will drop and then more water is allowed in. In your case it appears the 'half full' reed switch is being activated because the solenoids are not closing off properly and water is leaking in and filling the tank. If you do not empty it then eventually it will fill and leak into the leak. The problem can be caused by either low water pressure (below 145 psi) or sticky solenoid. If is the solenoid then the Miele solution will be to replace both solenoids. Alternately you may be able to remove, take apart and clean. Also check that you have a mesh filter at connection to tap. Also you can temporarily fix the problem by turning off the water at the tap and re-programming machine to 'turn off' the plumed water line. regards
3answers
My Jura Capresso E 8 is stuck in open tap filling system. I open tap it says filling system, it says close tap, when I close the tap it goes back into open tap. Float valve looks fine, water is moving
Open the tap with frother spout off. This happened to mine and I took the frother tip off and opened tap with tip off. Water filled and I closed tap...Machine returned "Ready". I heated water in microwave for three minutes- placed frother tip in hot water and all kinds of gunk came out. Lesson learned- Do a thorough cleaning of frother by immersing it in very hot water at least once monthly- even if you don't use it
My washing machine is WA80F# water from the inlet pours so slow even there is high pressure of water from the faucets what to check please
Check the actual inlet valve, it may not be opening all the way. Sometimes a good sharp whack, will fix it. Other times it must be stripped down and soaked in a solvent for a bit.
3helpful
3answers
How to clean a fuel tank after years of storage
Remove the gas valve assembly. Get a cupful of 1/2" nuts from the hardware store and put them in through the gas cap. Add 1/4 tank of kerosene or other "slow to burn" solvent. Put the cap back on the shake the metal nuts all around inside the tank. The nuts will abrade the rust and gunk so you can get the tank nice and clean. I suggest you then use a liquid tank liner. Google kreem products as a source. Now the tank will never rust again and you will get clean gas.
Could you take a moment and rate my answer? Thanks!
8helpful
2answers
I can't get past the 'open tap'/'close tap prompts on my Impressa
I had this problem with my Ena 3. The difference was that water was actually passing through the nozzle, but when I turned the dial back to the coffee symbol it would just tell me to open the tap again.
The solution was simple thanks to bergend's post, although I'd never have thought of it independently. I emptied the water tank and filled it back up with luke warm water instead of the cold water I had been using. After the first "system filling" round, the machine continued with the setup program fine.
So, to others with this problem: don't use too cold water in the tank for the first setup, even though the manual tells you to. Luke warm works great.
Water storage tank
you seem to have a loose connector inside you have to open the machine and look at those connector tapping the machine is gonna work for a while it good to open loose connector short out you dont whant that thanks fao using fixya pierre
1helpful
Hoover floor mate
When you place the clean water tank on the machine, there is a connection between the tank valve and the seal on the body of the unit. If you have been using the wrong solution, ie. lysol or pine sol, they contain elements that will cause the seals to absorb the solution and they will swell and the valve will not open to release the solution into the machine. If this is the case, you will have to replace the main seal on the machine and the small seal on the valve in the tank. I have seen this problem alot because it can be hard to find the proper solution that was designed for the machine.
Put cold water only in the tank and place it on the machine. As you are pushing it into place, look through the clear plastic of the tank and observe the valve. You should see it lift slightly and hear the "glug" of water flowing. You should also see bubbles rise up inside the tank. If this doesn' happen, then the seal and valve are probably compromised and will have to be replaced. Don't use any solutions or additives that contain petroleum distolates or solvent bases as these are the main culprits that will be absorbed and distort the seals.
Jan 13, 2008 • Vacuums
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Grand Canyon Tech
Grand Canyon Tech
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
