Element Electronics FLX3210 32 in. LCD TV Logo
Ralph Aker Posted on Apr 20, 2015
All hdmi pictures come and goes - Element Electronics FLX3210 32 in. LCD TV
HDMI 1 port stopped working
you have input problems with HDMI 1 I would use 2 and leave it alone. You cannot repair this yourself.
Aspire 6930 HDMI output shows only part of picture. Used to work correctly.
change the settings in the display adaptor for the HMDI. They may also be accessible in the display icon of the control panel.
RX-V465 output HDMI 1 will work but HDMI 2-4 won't, also when I hook up Wii via rca to receiver only get sound no picture.
This receiver has only one HDMI output, but 4 HDMI inputs. If some inputs don't work, try connecting the equipment (DVD for example) to HDMI input which works with other equipment....
For the RCA (composite) video input - it won't work, because this receiver don't have any video processing circuit.
So HDMI input video goes to HDMI outout connector.
Composite (RCA) video input goes to Composite outout and no other video output.
S-video input goes only to s-video output.
Our receiver is connected to our cable box via an HDMI cable. Picture and audio show up fine, then goes out for a minute and then comes back--this keeps happening. Every time the picture/sound disappear,...
Connect the TV directly to cable box to make sure the TV and cable box are ok. If you have picture then the receiver is no good. Some Denons have problem with HDMI board (digital unit).
Picture goes of and on with HDMI1 on screen sounds stays on
This sounds like the signel board is going out in the HDMI jack and needs replaced! Also try another jack to make sure its not the cable!
Please rate my response!
Rhank You!
Compatibility with Samsung LCD Display
It sounds like the HDMI port on the back of your Marantz is damaged. if you know for sure that the HDMI port works on another tv still you might just use component connection because the visible difference between component and HDMI is not very recognizable.
1helpful
2answers
JVC LT-32DS75SJ issue with HDMI
Try this
1. Turn ON TV
2. Connect PS3 to TV HDMI input
3. select TV HDMI input for PS3
4. turn OFF PS3 if it is ON
5. Press and hold the [I/O]Power button until the PS3 until you get the "HDMI Detected" message.
Also, this TV has a circuit that deactivates the HDMI if the rear cover is removed. It is possible the HDMI may have been turned OFF. This is reset in the service menu of the TV.
No picture but sound on panasonic plasma
Unplug the TV and disconnect any HDMI cables to the set. If the issue goes away there is a possibility that your HDMI source is causing the problem. Anything on the HDMI can cause odd problems with the TV since the serial data and serail clock lines are routed on HDMI. Those are the 2 commmunication lines used throught the TV for operation so anything HDMI that might load down one of those can cause issues.
Hi guys, don't know if the previous post got through. Have a new LCD tv and DVDr, connected with a HDMI cable. when DVDr switched off analogue and digital picture is fine. as soon as dvd is switched on...
yes, hdmi will give you better results..
are you running hdmi to hdmi connection on tv from cable box?
if so, that is correct but as for the dvdr, what tv port are you connecting it to? i would use another hdmi cable for the dvd too for best picture resultif it's an option on your dvd.. you should have multiple input outlets on your lcd with 1-3 options for input devices via analog or hdmi.. so analog is not hdmi--hdmi is digital so it switches to the hdmi resolution when you turn it on..
let me know how it goes and if i was helpful involving resolution.. helpful feedback is appreciated.. thanks, d
your dvd player should be set to a different
Top Element Electronics Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
