Here's a link to the Pride Tech Manual guides. Click on the 1103 for a PDF file.
http://www.prideservice.com/TechnicalProductGuides/technicalproductguides.asp
The wiring is pretty simple and straightforward. These operate on a 24VDC system provided by two 12VDC batteries. Power from the batteries goes to the controller into a Joystick/controller combo. It leaves the joystick down to each motor/gear/brake assembly. Power to the batteries comes from the charger which puts out 28VDC, with a 120VAC input. Very rarely does any of the wiring go bad excepting those people who grossly overload the chair, or run it into fixed objects at full speed. Other mishaps with overamping are caused when somebody tries driving over unstable surfaces like sand, gravel, mud/wet grass and spin the motors. This drives the controller crazy because its job is to keep the chair pointed in the right direction, and with wheels spinning, it doesn't know what to do. Overheating the motors or controller, or both. There are two sets of "brushes" on each motor that carry the current from the batteries to the motor. These are located under a black-plastic slotted screw port at the ends of each motor. Removing the plastic screw reveals the brush. It should have a flexible semi-copper lead that shows no evidence of overheating, or brittleness, and should be about 3/4 of an inch long. If 1/4 of an inch, it should be replaced. Check all four. Good luck.
SOURCE: The power lift seat on my wife's Jazzy 1103 Ultra won't actuate.
most actuator motors have an in-line fuse, I think the one for pride 1103 is located under the cover at rear of chair or close to actuator motor
SOURCE: just bought a very slightly used 1103 jazzy. no
It sounds like you need a new charger. If you have a voltmeter and are somewhat mechanically inclined you can check this. You can email me at [email protected] and I can give you the steps to cheching it.
SOURCE: problem with joystick on Jazzy 1103 ultra
You will need to take it in for repair. 8 bar flash usually means you have a bad joystick/controller. They can sometimes send it in to the manufacturer to have it repaired. Find a reputable dealer and relay this info to them.
SOURCE: i need the pinout of the jazzy 1103 ultra battery
The Output voltage 24 - 29v ,Usually 27v. (And 4 Amps)
The Pin arrangement is Negative to the Left, Inhibit in the Middle, And Positive to the Right Assuming your looking into the plug itself from the front.
Always check with a Voltmeter first though because there are some chargers with the Opposite Pin Arrangement.
SOURCE: y mom's jazzy 1103 ultra will not operate .
Make sure motors are in gear. Unplug from wall then try to turn on.
