Farberware Rotisserie Grill Indoor Hearth Broiler Logo
M
Mary poole Posted on Apr 19, 2015
We bought a farmer ware rotisserie and the cord next to the plug is hot. We moved it to another outlet but it's still hot.
Lynn Lenin
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 04, 2015
Lynn Lenin
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1004
Points
The cord to the Faberware Rotisserie will get extremely hot. I am on my third cord because the other two got so hot that they caught fire. The grills are nice to cook on, but never leave them unattended when cooking
2answers
The outlet plug gets very, very hot
STOP using the unit immediately. Your plug getting very hot indicates a very poor connection somewhere between your outlet and the oven switch. This is definately a fire hazard so do not use the unit until you have found and fixed the problem. It could also be the outlet itself not making a good connection with the plug. Look at that first. If the plug doesn't fit tight in the outlet, the outlet must be replaced. If the plug is tight, you may have a switch in the oven itself with a poor connection. The oven must be taken apart to find out where the problem lies if your outlet is good. You may find parts that are melted in the oven which would indicate a problem. It's hard to say exactly what the problem is without actually looking inside the oven to see whats going on. Whatever you do, DO NOT use the oven until the problem is fixed or the oven may end up being the least of your problems...
Bought the GE Rotisserie oven model 169220 used. It is missing a rotisserie spit. Where can I buy one?
Visit http:///www.gehousewares.com/Customer_Assistance.aspx,
you will be able to find there how to order parts.
Regards.
I bought a Euro Pro TO242RW convection oven and Rotisserie. No manual or rotisserie spit. were can i get these things. Thank you.
Have you tried to find the Euro Pro website to look there? Have you searched on the internet using Euro Pro, model,and the word manual because there are sites that offer manuals on products. And the same thing for the rotisserie part. Maybe doing that will give you leads to look further if need be.
<a href="http://www.toasterandconvectionovens.com">ToasterandConvectionOvens.com</a>
I just bought this oven & my daughter lost the manual that goes with it. I need to know how to use the rotisserie feature. Also need to know if the rotisserie can be used for a roast. Thank you. =)
You might not want to use it again after your first experience. Make sure you get your food balanced as the motor on this thing is very weak. I cooked 2 chickens and a loin roast when I first got it and they were no better than pan roasted and a lot more trouble.
I have posted the complete manual (3 language edition) here:
http://216.92.50.93/Manual.pdf
2answers
I have a CO1500 and I'm looking for the thermostat assy for it (the contacts are fused together). What is the part # for this assy and do you know where to purchase it?
You may have a problem. I have a CO1500B, and am trying to find parts for it. I have been told that their factory does not sell the parts separately. You can buy trays, rack, rotisserie parts, etc. No repair parts for oven itself though.
2answers
This toaster oven gets extremely hot
Definitely return it. It has a partial internal short which is appying full power to only part of the heating element causing th excessive heat. No properly working appliance should make the outlet hot.
2helpful
2answers
Recall: I bought a Euro Pro Convection/Toaster Oven w/Rotisserie and it caught fire today from a non-food related problem. Is there a recall on this item? There was no food in the oven and it was...
Today I was warming up a baked potato in mine it was on 350for about 20 min when I went to shut it off the nob melted right off the ovenit was so hot I could not shut it off had to unplug it and the top of the ovenwas also very hot, is there any recalls on the MODEL # TO161
2answers
Toaster Oven Unresponsive (Farberware Model# FT032055
I would check the cord or the plug before anything else. Plug another appliance into the outlet if it works try bending the male plugs on the cord slightly and try again. If this doesnt work call the man.
2helpful
Lost instruction manual for Bravetti Model#TO285 toast/conv.oven
The same unit was marketed under the Euro-Pro name, with the same TO285 model number. The manual, as a PDF, as well some replacement parts are available at this link:
http://www.euro-pro.com/europro/default.aspx
Hope that helps.
Top Farberware Toaster Ovens Experts
vince
john h
ADMIN Andrew
ADMIN Andrew
Are you a Farberware Toaster Oven Expert? Answer questions, earn points and help others
