Seagate Free Agent Go Small 12 GB USB External HD ST600121GSA1E1-RK USB 2.0 Hard Drive Logo
Posted on Jul 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a problem with my seagate agent go 500 gb. when plugged in to my laptop it doesn't detect it and it freezes my laptop until i unplug it. how can i get to my files in the external hard drive?
Anonymous
Level 2:
  • Expert 79 Answers
  • Posted on Jul 10, 2009
Anonymous
Expert
Level 2:
Answers
79
Questions
0
Helped
26857
Points
235
Try to connect it to other computer, if it doesn't help, hdd is probably broken. If you disassemble, you will find internal hard drive, which you can try to connect to desktop PC to save your data, or look up for some data recovery company
My extenal Hard disk seagate free agent 500 gb is not detected by my laptop
try all usb inputs. if it still isn't try another computer. It should be found. Make sure it is plugged in just right or wiggle to see if it finds it. if not then maybe the hard drive is 3.0 usb and the computer is 2.0 just some thoughts
My Dell Inspiron 1545 laptop is not recognizing seagate free agent go 500 gb external disk. It used to work fine all the while until I used it on another system. I have tried changed the usb cable but...
check in the bios if it is showing HDD detected
.if there in bios HDD not detected then there is problem with HDD (change the HDD ) or
go in bios and ...check sata settings
.change the sata settings n then ...install again
I received this message about Seagate Free Agent Go 500 Gb: Cannot find the specified file. Make sure you specify the correct path and filename.
It seems that your Seagate Free agent has lost it connection to your laptop because of the problem in usb cable
Try to unplug the usb cable from your laptop and plug in again
1helpful
Seagate free agent external drive not getting detected
ok here goes, my neighbour has the Seagate FreeAgent Desk 500GB, and in under 2 weeks it started to beep and was not reconized by any Laptop or P.C. if this is the same for you with any FreeAgent Desk series ( not GO series, different procedure for GO products). You maybe in luck click this link, you may have to register in the forums to view thread.... http://www.yo-lid.co.uk/forum/viewtopic.php?f=32&t=84 hope this helps Ytee.
2helpful
My seagate 500 gig free agent desk external drive has suddenly stopped working. It was working fine 2 days ago and then yesterday it apparently wasn't connected so I reconnected it and then it seemed to be...
Do a FULL POWER DOWN Reboot. and try a different USB outlet in the PC... same Laptop to see if it is in your PC that is causing the problem.
Note: Most of those Drives do stop unless they are connected to the PC... energy savings.
If that didnt work... you could have a failed drive. Seagate should help you do some diag if it is in warranty... typically 3 years.
2answers
Seagate free agent pro 500 gig external hard drive NOT RECOGNIZED
You better check with the Seagate people. This seems to be a problem with the casing. And since you're under warranty, you can get a replacement.
Seagate 1 TB not detectable on win 2003, xp detects it
As you know,the Seagate sometimes has the firmware problems,so it seems that this firmware designed only valid in XP or Vista system,you may find the firmware update from the seagate official website
2answers
No Power to my Seagate FreeAgent Pro 500GB
I think you screw yourself... you have just burn your files
2helpful
4answers
Help for Seagate Free Agent 500 GB external hard drive
465.66 x 1024 x 1024 x 1024 = 499,998,617,764 bytes. The problem is the definition of gigabytes.
Top Seagate Computers & Internet Experts
Sean Wright
Sean Wright
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
