Frigidaire FEB27S5A Electric Single Oven Logo
Posted on Dec 28, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Our frigidaire flat-top electric stove stopped working
Our frigidaire flat-top electric stove just randomly stopped working last night...it is plugged in but the clock is not illuminated...when i turn the burner on, the clock comes on but the burner does not...is there a fuse or reset button...any ideas?
btw, it seems the stove still works fine...
Melissa Martin
Level 3:
Master:
  • Frigidaire Master 753 Answers
  • Posted on Jan 01, 2018
Melissa Martin
Frigidaire Master
Level 3:
Master:
Answers
753
Questions
0
Helped
196260
Points
1330
Sound like you make have a loose neutral on the cord where it attaches to the range or in the electrical receptacle where it plugs in, you can check the cord by pulling the range out, remove the small access cover to the cord connection area, after you have unplugged it and just tightened all the nuts to all connections on the cord. I advise an electrician to check the receptacle. I hope this has helped you. Have a great new year.
5 Related Answers
meowwl
  • 19 Answers
  • Posted on Nov 19, 2007
SOURCE: burners on gas stove work but oven and broiler not working
Most ovens, unless they have an electric igniter (does it go tick tick tick when plugged in and turned on? If so, it has an electic ignition.) have a pilot light. In order to keep gas from flowing out, and to prevent a possible explosion when the pilot light has gotten put out, they have an electric thermocouple on them that shuts off the gas when it gets cold. Plug the cord back in, and relight your pilot light by holding the lighter (I recommend a fireplace match or bbq lighter, not a cigarette lighter to prevent singed knuckle hairs!) over the thermocouple for a couple of minutes.
Anonymous
  • 770 Answers
  • Posted on Jan 21, 2008
SOURCE: Frigidaire non-digital (old) Caprice top electric oven not working
Check the clock knobs the older style you had to push in to auto time them make sure the times are on the same time (stop&start) and the buttons are popped out to engage the upper oven if so post the complete Model # and i will get the manual for you
Anonymous
  • 121 Answers
  • Posted on Jun 02, 2009
SOURCE: My Frigidaire electronic self cleaning oven (ES IV)is beeping and flashing F1 and I cannot get it to stop or reset.
Disconnect the plug to oven and let set for 30 secs then re plug into receptical
Anonymous
  • 3361 Answers
  • Posted on Jun 26, 2009
SOURCE: Frigidaire Oven - lights are on but no heat from oven or burners
You must check your incoming power for 220 volts. You have lost one leg of your power. Either a bad breaker or bad wall outlet or bad range cord.
Anonymous
  • 1891 Answers
  • Posted on Dec 04, 2009
SOURCE: Frigidaire ES200/300 316257123
look for a shorted bake element .. you should be able to see where it poped. ( some times ) if you have ohm meter you can ck for an open element . **** //
Frigidaire FEF366CCB classic series electric oven. While I was away the oven stopped working. No heating elements in the oven or stove top at all work. The EOC still shows time, no fault code. Ideas?
check breaker or power feed my not be getting correct power to the unit may only be getting 110v which electronic circuits work on instead of the 22ov that the elements and coils work on
10helpful
2answers
Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
8helpful
2answers
Manual for Stoves EL716 oven
I have a Stoves Newhome EL716 double electric oven and last night, it just lost all power and stopped working - no grill, oven, lights, clock or anything. Can anyone tell me what this could be please? Thank you.
My right front burner will not turn off on my electric stove top.
Its probably the switch for that element, the contacts are fused. If this is a smooth top ceramic stove then the control relay board relay for that element is stuck.
1helpful
Oven stopped working while cooking a meal
it sounds like it burnt one of your main wires in the back of range. by turning a knob on you are getting a feed back. turn the power off remove back panel take a visual check of your wiring.
Top Frigidaire Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Kell Le
Level 1 Expert
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
