Yellowing is a sign of age, but plastic items can be brightened up a bit. Here are some suggestions:
http://www.howtocleanstuff.net/how-to-whiten-yellowed-plastic/
SOURCE: american standard whirlpool tub #2425
Here is the link to installation instructions:
American Standard #2425
The information you need is on page #7.
Hope this helps!
SOURCE: how do you remove the jets on an american standard whirlpool tub
The jets have a nut on the back of the jet. I hope you have access or else you will need to pull the tub for this job. Loosen the nut and squeeze aquarium grade silicone in between the tub wall and the nut, Tighten the nut, but not to tight. Let set over night fill and check for leaks the next day.
SOURCE: i have an american standard jet tub, but i lost
You can adjust the jets by moving the center of the jet around, if the center does not move, it is not adjustable, some jets have a pressure adjustment by twisting the center of the jet left to right. No manual necessary for this.
SOURCE: My American Standard spa tub Williamsburg Elite
sounds like maybe the jet faces are turned off. see if they turn one way or the other and they may open and spew water out for you.
SOURCE: I have an American Standard
You can find replacement jet trim at the following source.
US Parts Center
Hi there, I bought a house last year and it has this tub, but for the life of me I cannot find the model name/number. Also, it certainy doesn't seem to be a current model according to the selection on their website. Do you happen to know? It would be a huge help.
Thanks much,
Anthony
