Question about Homelite Mighty Lite Lawn Trimmer
Starter spring rewind - Homelite Mighty Lite Lawn Trimmer
2 Suggested Answers
SOURCE:
SOURCE: Homelite H B 100 leaf blower.
wind back up again, and place it in in the stops, it's that simple
Posted on Jun 28, 2010
Where can I get a spring for my saw ?
How to Replace the Pivot Spring on a DeWALT DW708 ...
? 6:48
https://www.youtube.com/watch?v=xz3EPWHjj0A
Aug 9, 2012 - Uploaded by eReplacementParts.com
Dammaged pivot springs can prevent your saw's cutting head from staying upright and, as a result, cause a ...
Replacement Parts ' Pruners ' Loppers ' Saw Blades ...
coronatoolsusa.com/replacement-parts.html
Items 1 - 12 of 268 - $0.00 (0 Item). You have no items in your shopping cart. MyAccount ยท Login ... Spring for AG 4980SS. 4980-5. $8.53. Spring. 6310-5C. $7.11 ...
Shop for Where can I get a spring... on GoogleRecoil Starter Spring Homeli...$10.00eBaySpring Starter Chainsaw Ech...$4.99eBayHomelite 26lcs, 5?20, 5?30n, 6...$24.00eBayMcculloch Chainsaw Spr...$13.99eBay5x Husqvarna 362, 365, 371...$19.75BonanzaSearch ResultsHow to rewind a pullstart spring - YouTube? 5:05https://www.youtube.com/watch?v=qTcL3_3leTkMar 13, 2010 - Uploaded by lenniepincherIf you ever need to rewind a un coiled pullstart spring. This might help you. It took me ... First pull of my chain ...Chainsaw Rewind Spring Replacement - Echo ... - YouTube? 3:38https://www.youtube.com/watch?v=oqcjL7W0XMAFeb 18, 2013 - Uploaded by RepairClinic.comThis video provides step-by-step instructions for replacing the rewind spring on Echo chainsaws. The most ...
Dec 12, 2015 | Garden
Starter pull rope does not rewind spring broke how to tear down
How to Rewind Recoil Starter Spring Quick Fix This page also has videos explaining how to remove and replace the cover with recoil spring.
Sep 01, 2014 | Polaris Scrambler Men's Mountain Bike
The rope broke when I tried to start the chainsaw. How do I replace it?
Your rewind spring is now sprung. Remove recoil assy ( the part your rope slides into). Remove all old rope remnants and rewind the spring. Install new rope, tie it off and slowly release spring rewinding the rope.
Mar 14, 2014 | Stihl 017 018 Ms170 Ms180 Chainsaw Starter...
Husky power washer 2600 Tried fixing starter
I'll send you a link to a great video of how to recoil a starter spring, so you wont lose and fingers or eyes. :)
Aug 01, 2013 | Garden
Starter cord won't rewind
The starter cord is spring loaded. When the spring breaks your cord won't rewind. Usually the whole starter cord assembly is easily replaced and readily available at your local gardening goods retailer. They might even install it for you for a nominal fee. I hope you find this solution helpful. Please rate it and thanks for using Fixya.
Nov 05, 2009 | Sewing Machines
Strimmer Starter strip
You will need to take the housing off to expose the rewind mechanism. The most likely cause will be a broken rewind spring. Go on the WEB and search for your model and a part list. Locate the spring and order it. Once you install the spring, you will need to pre-tension the spring by by pulling the cord part way out and ciol it on the spool. Good luck
Jan 01, 2009 | Garden
THE STARTER REWIND SPRING IS BROKEN
you can not fix recoil spring all you can do is replace it.never said what the recoil is on so cann't help till you tell what it is on........
Dec 25, 2008 | Garden
Spring repacement
Hi fwadden
Remove the housing-fan. Remove the screw and detach the pulley- starter and the spring -starter.Put the new spring-starter(it usualy comes with a support).The spring-starter"spires are counterclockwise oriented.Put the puley starter back and the screw.Wrap up the rope clockwise on the pulley-starter until the starter works propperly.Hope this helps you.
best regards savumihai71
Dec 12, 2008 | Poulan Pro Chain Saw 46cc 20"
Poulan Wild Thing 18 Inch replace starter spring?
A new spring comes wound tight enough to be dropped into place in the starter housing (Easiest).
I invert and secure the starter housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension to retract properly.
If you're lucky you can pull the cord out enough for a pretension then slightly raise and add the withdrawn cord to the spool.
Both methods require about 2 turns of pretension to rewind the cord when pulled.
Lou
Oct 09, 2008 | Poulan 1630 16" Chain Saw
Homelite Mighty Lite Lawn Trimmer  Logo
120 people viewed this question
Top Homelite Garden Experts
roeb
Randy Schumann
Randy Schumann
lnbn1975
Are you a Homelite Garden Expert? Answer questions, earn points and help others
