When i start my printer it always says this word in front panel : 092-651 code : 2880000 restart printer conntact support
Found you a suggested solution, here on fixya:
Can print on fuji xerox docuprint cm215fwcode 288000restart printercontact...
SOURCE: Fuji xerox won't pick up paper for printing.
Managed to get it going ,pulled all the toner cartridge out and reset and all is sweet.....!
SOURCE: my fuji xerox printer docuprint 203 A's drum
Press the button until all the lights are on..then let go the button, this will reset your drum counter.
SOURCE: my Fuji Xerox Printers DocuPrint 203 A got
the drum or toner LED? if it's the drum, then just press the button until all the LED are ON then let go and this will reset the drum..
if it's toner, you need to take out the toner and on the left side of the toner, there is a level, unscrew the 3 screws and turn the level to the other side, re screw the whole cover and install back to the printer, this will reset your toner, make sure there is toner in the cart.
SOURCE: where can I download the driver for Fuji Xerox
You can download a latest driver for Fuji Xerox Docuprint c1110b Color Laser Printer in this URL
http://www.fujixeroxprinters.com.au/en/support/Downloads.aspx?product=8645&category=5726&os=8388608
Driver Version: 2.6.15
Driver Languages : English, Chinese - Simplified, Chinese - Traditional and Korean.
Operating System
Microsoft Windows XP Microsoft Windows 2000 Microsoft Windows 2003 Microsoft Windows 2003 64bit Microsoft Windows Vista 32bit Microsoft Windows Vista 64bit Microsoft Windows XP 64bit Microsoft Windows 2008 64bit Microsoft Windows 7 Microsoft Windows Server 2008 Microsoft Windows 7 64bit
Printer Language: PCL
WHQL: Yes
SOURCE: FUJI XEROX DOCUPRINT C1110 WRONG PAPER SIZE MESSAGE
This printer have a sensor to remind the user when using a wrong paper size.
If you still using a paper that not the same with your software settings, it's still reminds you.
I solve this promblem by after print my works I just press "Cancel Jobs" button to clear a data.
Good luck.
Hi HANDY , I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
well when I turn on my printer it says restart printer or contact support
Do you have any information or technique that can help?
