Belkin TuneCast 3 (F8M010) FM Transmitter Logo
t
tosah luis Posted on Apr 16, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What are some of the problems faced when building an fm transmitter
A low power fm transmitter
Marvin
Level 3:
Top Expert:
  • Belkin Master 85,242 Answers
  • Posted on Sep 20, 2016
Marvin
Belkin Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29037871
Points
266281
Skill level of builder.
1helpful
Can I hook up a mp3 or phone up to my jvc kd-s570
The KD-S570 does not support an Aux device (MP3 or phone) either with a Bluetooth or 3.5 mm connection directly. There are FM modulator or FM transmitter to Aux device retrofit kits that you can build/buy. (The FM transmitters require less work but can have lower sound quality.) The manual and specifications for the KD-S570 are available from the product support site: http://support.jvc.com/consumer/product.jsp?modelId=MODL026430 .
I wish that I had better news for you.
2answers
Wont pick up fm
Deploy the antenna, and orient it. Keep the radio away from electric appliances such fridges, and electric machines. Put the radio on a window sill or close to a window. If a building blocks the line of sight between radio and transmitter reception may be affected.
WANNA PLAY MY XM FROM MY PHONE WIRELESS THROUGH THE RADIO
Buy the device 'FM Transmitter' and power up it in mobile charger hole.
If you want to make it happen through your phone then get a handset with in-build fm transmitter.
Set the frequency of the fm transmitter app. as same as in the head unit. Play a music in your phone or calls...
You have done it!!
Pls rate
1helpful
2answers
My Belkin F8Z441 has stopped working after a month. It's charging my iphone but the transmitter doesnt work at all. No display. Please help...
wrong... you need to open device to check the cable connections... due to the devices ability to turn this pulls out some of the connections.
1helpful
2answers
Can we fing & install fm transmitter for sony
no you cant it should be inbuilt in your phone . in w995 fm transmitter is not there
IS THERE A WAY I CAN PLAY IT IN MY CAR IN THE RADIO
Yes, You will need to purchase a device called an FM transmitter, it plugs into the headphone jack and transmits the sound to your FM radio. The transmitter will have station settings, you just find a radio frequency that does not have a station in your area, set the transmitter to that and tune your radio to the same frequency. You can get the transmitters from Walmart electronics dept, Target, Sears, Amazon.com, Radio Shack and most other electronics retailers. The transmitters run about $12-20 and can be battery powered or plug into your car power outlet. Go to google.com and do a search for "MP3 FM transmitter" and you will see what they look like.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Is it possible to connect my PC to my outdoor speakers? I want to play music outside using my PC. Is there a special connector that I need?
There are a couple of ways to go about this. The first would be to locate a similar computer speaker system set up outside - provide power and extend the cable to them - if not too far. When you want to listen to the outside speakers, plug the cable into the headphone jack of the computer. Adjust volume and enjoy.
Another way, would be to buy (or build from kit form) a low power FM transmitter. These devices are available in mono & stereo types and will play over all FM radios and stereos in a 50 to 300+ foot radius (depending on antenna, wall construction, transmitter power, etc.) when they are tuned to the transmitter frequency. These can be found for under $100 or built for as little as $30 or so. The upside to this method is that the music is available over ALL radios nearby.
Still another way is a wireless speaker system. This works like the FM transmitter, but will only work on these particular speakers. These will require power only - but some will work from internal batteries as well as AC power. The system includes a small transmitter, power cord & cable to plug into a headphone jack - all for use at the computer, and two speakers - each with a power cord as well and possibly a remote control.
Use of a spare pair of old stereo speakers will probably not work as the computer's sound card rarely develops more than a watt or two - and most home speakers require 10 or more watts to be driven properly.
10helpful
I need to know how to turn it on...i don't know if its broken or what...cuz i put in new batteries and it won't trun on
1. Open the battery cover on your TuneCast II Mobile FM Transmitter. Install the included AAA batteries and
replace the battery cover.
2. Plug the 3.5mm connector into your iPod player or other portable music device.
3. The AUTO ON feature will power on the FM Transmitter when the unit detects an input signal. Your FM
Transmitter’s “AUTO ON/OFF” feature uses your audio player’s volume level to automatically power on and
off.
For best results, keep your player set at a medium volume level. NOTE: Setting your device volume very
low may cause the FM Transmitter to turn off, even if the audio player is on.
You can also press and hold
both and buttons simultaneously for two seconds to turn on the unit. To turn off the unit, press
and hold both buttons simultaneously again for two seconds.
1helpful
2answers
STATIC/INTERFERENCE
&R=11812445&C=17577363&K=NBy0rr?h=2mv3s7&r=11812445 Your SIRIUS radio contains an FM transmitter that allows it to operate wirelessly through your car FM radio. We have determined that the output of this transmitter exceeds the limits established by the Federal Communications Commission (FCC). As a result, the unit may interfere with the performance of radios operating in areas adjacent to your radio. There are no health or safety concerns associated with this issue.
  • If you listen to your SIRIUS radio wirelessly through your vehicle's FM radio, then please review the solutions listed below and select the one that works best for you. SIRIUS will provide you the best solution at no cost.
  • If you use your SIRIUS radio only when docked in a boombox, or directly connected to your car radio or home stereo using audio cables or a cassette tape adapter, then no interference can occur and no further action is required, provided you have turned off your FM transmitter. To turn off the FM transmitter, first press the MENU button. Use the channel up/down buttons to highlight “FM Transmitter” and push the SELECT button. Use the channel up/down buttons to highlight the "FM On/Off" menu item and then press the SELECT button. Use the up/down buttons to highlight "FM Off" and press the SELECT button. To exit the "FM On/Off" menu, press the MENU button. Use the same procedure to turn off the FM transmitter if you use Solution 1 or Solution 2 below..
Solution 1 - Direct Wired Audio Connection: If your vehicle radio has a “LINE IN” or “AUX IN” jack, you can use a stereo cable to connect directly to your SIRIUS radio. This solution is the easiest to install and provides the best audio performance. Many newer vehicles provide the required audio input jack. It will normally be found on or near the front faceplate of your vehicle’s radio.
Solution 2 - Cassette Tape Adapter
: If your vehicle has a cassette tape player, you can use a cassette adapter that allows you to play your SIRIUS radio through the cassette portion of your vehicle radio. The adapter slips into your vehicle radio as easily as a cassette tape and provides better performance than a wireless connection. fcc_a_2.jpg
Solution 3 - FM Extender Cable Kit: An FM extender cable will provide a special transmitter antenna that allows you to obtain the best audio performance through your vehicle’s FM radio. This solution is easy to self-install, but does require that an easy-to-hide wire be run in your vehicle so the transmitter antenna can be placed in close proximity to your vehicle’s radio antenna. Using this FM Extender Cable Kit, you will continue to use your SIRIUS radio exactly the same way as you do currently. fcc_a_3.jpg
Solution 4 - FM Direct Adapter with Professional Installation: An FM Direct Adapter provides a wired connection between your SIRIUS radio and your vehicle’s radio. You will continue to listen to your SIRIUS radio through the FM tuner of your car radio, but the FM Direct Adapter eliminates the outside static and interference you sometimes experience when using a wireless FM connection. This solution usually requires professional installation. We will provide a certificate redeemable for installation at an installation center in your area.
Please go to www.sirius.com/optimize and select the solution that works best for you. If you have any questions, please call 1-(877) 635-5130. Detailed instructions will be included with your solution.
You will improve the performance of your SIRIUS radio and reduce the potential for interfering with adjacent radios if you properly tune your FM transmitter. Please see the FM Transmitter Set-Up Tips below for more information.
We are sorry for this inconvenience. We are confident these solutions will allow you to continue to enjoy the great music, news, sports and entertainment that only SIRIUS Satellite Radio can offer with no impact on your radio’s performance.
Sincerely,
SIRIUS SATELLITE RADIO
To tune your FM transmitter turn off your SIRIUS radio and tune through the FM channels on your vehicle’s radio to locate an FM channel (except 87.7/87.9) that is not broadcasting in your area. If you use an FM channel that is being used by a local broadcaster, it will interfere with the performance of your SIRIUS radio. Once you have located an FM channel that is not being used for broadcasting in your area, save it as a preset on your vehicle radio. This will become your SIRIUS preset. If you’re not sure which FM channels are not being used in your home or travel cities, you can go to www.sirius.com/fmchannel and search for an FM channel based on zip code.
Turn on your SIRIUS radio. In the SETTINGS or MENU on your SIRIUS radio, locate the “FM Frequency” adjustments. Set the channel number on your SIRIUS radio to match the SIRIUS preset on your vehicle radio. Refer to your user guide for detailed instructions on how to do this. The FM transmitter in your SIRIUS radio is automatically set to FM channel 88.1. This may not be the best channel in your area.
Top Belkin Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Belkin Audio Player and Recorder Expert? Answer questions, earn points and help others
