I'm not sure about the 922, but other SPA phones can be reset without an admin password: hit the menu button, press 14 on the keypad, and OK the reset.
"The default log-in credentials for de Web Config Interface are "admin" for the username and the password you create the first time around. As with all routers, you can always restore it to default factory settings via the recessed reset button on its back."
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
To reset your SPA device to the factory default values, follow the steps below:
1. Disconnect the Ethernet cable 2. Access the voice menu (****) and press 73738#. 3. Login with the username "user" when accessing to http://spa-ip-address OR login with "admin" when accessing http://spa-ip-address/admin/.
NOTE: Resetting your unit will erase all the configuration settings. If your SPA device was provisioned by a service provider, the reset function might be password protected. Contact your service provider.
Plug the phone in and allow it to boot up. Once the home screen is displayed, press and hold the 4, 6, 8, and * keys for about three seconds, or until you hear an audio alert and the phone asks you for a password. Enter 456 (default Admin password) and the phone will default itself. If the password has been changed, and 456 does not work, enter the MAC address of the phone as the password. Entering the MAC address of the phone will only reset the Admin password to the default, so it will probably be necessary to repeat this procedure, entering 456 the second time, to factory default the phone.
You can reset the router password but it will go to the factory default setting. Are you sure you know how to configure it back then do one thing take a ballpen and press the reset hole switch for 30 seconds or untill all the lights or single power light blinks now most of the roter factory default username and password is Admin try it first then do resetting
