Stuck button
Precor Error 05, Key Depressed at Power Up
Probable Cause
1. A key is permanently depressed on the display.
2. An interface chip (IC) has failed in the upper PCA's keypad.
3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display.
Corrective Action
When the treadmill is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
Press the "ENTER" button three times to access the treadmill's error log.
Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
To view the treadmill's odometer reading when a particular error code was elicited, press "SELECT" while a particular error code is displayed.
Dear Sir:
Please try with this Reset system for Code:
To clear the error log, press "QUICKSTART" for a minimum of four seconds while viewing the list. Prompts will appear on the display and let you know when the log has been deleted.
If you need further assistance, please reach me. sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
