I just got the washer and dryer set last week. While washing my clothes in the washer the error code E1 and F8 came up. What does this mean? Thank you.
The washer and dryer are stacked in our garage and are brand new.
If you receive an E3 Error code, your washer may be unbalanced. This could be caused by the washer being too tightly packed, or clothing not distributed evenly. This will usually occur during the spin cycle. Stop the spin cycle.
F8 is taking too long to fill. Check the filter screens on the rear hoses.
The F8 E1 or Lo FL error code means your washer is not detecting the correct amount of incoming water. If the washer has an F8 E1 error or LO FL error, the door may be locked, and the control may be unresponsive. Aug 21, 2023
turn off the water and remove the hose at the rear of the machine. Inside you will find a small wire gauze strainer. This blocks with limescale and debris from the water mains, just enough to reduce water flow below the thresholds..
E1 F8 Whirlpool dishwasher
If F8 E1 or LF (too long to fill) appears in display, it means the washer is taking too long to fill. It's possible the drain hose extends more than 4.5" (114 mm) into standpipe.
Apr 5, 2021
"Sd" - (Excess suds)
F8 followed by E1 - (water supply error)
F9 followed by E1 - (drain pump system error)
F5 followed by E2 - (door will not lock)
F7 followed by E1 - (motor drive error)
"rL" - (remove load)
Washer making error beeps - Door has not been opened and closed for at least 3 cycles
Washer beeps when HOLD TO START is touched - Door not closed
F# E# code other than as described above appears in display - System Code Error
"nt" (interrupted) - Cycle was paused or cancelled
Clean Washer LED flashing at end of wash cycle - The washer has run 30 wash cycles and is indicating a reminder to run the Clean Washer cycle https://removeandreplace.com/2015/05/05/washing-machine-error-codes-front-and-top-load
My Maytag MVWX700XW1 washer does not spin, the lid lock light is flashing red and when I run the diagnostics, and check the Fault Error code I get F7 E1.
I would alos like to find the list of Fault Error codes.
Thank you for your help.
John
Press "end of cycle". Plug off the wall. Code can be an indication of several issues. The most common cause is over-sudsing in the machine. Overloading the wash with too much laundry may also cause the LE error code. Lastly, a breakdown in the signal between the microprocessor and the motor may cause that error code. This can occur if there is a loose wire, see that all wires are tightened..........
And rate me pl ...........if helped.
