My magic wand used to work very well, but recently I turned it on and it started whirring very loudly, like a fan in an old computer, but not vibrating very much. The body of the wand is vibrating a bit more, but the rubber head is hardly moving at all. And the noise is about four times louder. And when I shut it off, it whirs to a stop gradually, as opposed to stopping right away like before. How do I fix it?
SOURCE: Sounds like its working, but nothing happens
I had the same problem with mine, it's due to the fact that the smaller spring has become un-lodged from the ******** itself.
You will need:
1. Roll of electrical tape.
2. Utility Knife
3. A small slot head screw driver OR a pair of needle nose pliers.
The solution is to unscrew the silver ring so that is can be moved up
and down. Now, you need to use a utility knife and cut the blue rubber
off of the spring. Once you have the blue rubber but off you can see a
large spring with another smaller spring inside. Push the head of the
******** till the larger spring's coils are an 1/8 to 1/4 of an inch
apart. Next take either the small slot head screw driver or a pair of
needle nose and jam the smaller spring back into the hole in the center
of the white plastic piece inside of the larger ring. Next plug it in
to make sure the vibration is working, reattach the silver piece and
tape the larger spring with electric tape.
