Universal MX-900 Remote Control Logo
J
Joyce Gaiser Posted on Apr 13, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have to push really ******* the buttons to change channels...everything is just mushy!
Audio Service Clinic
Level 3:
  • Master 924 Answers
  • Posted on Apr 14, 2015
Master
Level 3:
Answers
924
Questions
Helped
351421
Points
1710
There are carbon contact on the back side of the rubber buttons, and after a while, these do not make a good connection. It can be cleaned, but that doesn't mean it will restore the functions. Best to buy a new remote.
How do i repair severe water damage on a uniden pc76xlw
I gyess the weather band overflowed.This is and isn't a problem yet. How long has it been since it has seen the water? try pushing down in several places on the pcb board to see if it is mushy and if it is mushy in any spot , you may as well toss it out.If it isn't mushy than you can try turning it on to see if it works. How long it would work I don't know but use it till it blows.
1helpful
I have an Element 32" LCD TV that is 3 months old. Everything works except I can't change the channels. If I push the channel number, it will go to that channel, but if I try to use the remote or the...
I talked to the manufacturer & they said that all I needed to do was to run the channel search, uninterupted, again. I did it & everything works. Thank you for your input.
Will not change channel by pushing button or by
go into the menu and select channels setup, select cable input if it is the case and then autoprogram
3helpful
2answers
Channel button on remote will not change the channel, nor will the buttons for up channel or down channel on the side of the tv work. You can change channels only by pushing the number buttons. My dad has...
go into the menu of tv find the option to auto program- let unit go thru process without interupting it.now chanels up&down should work-the problem was there were no chanels in its memory
How to change channel
Spirit GT: Programming a Frequency to a
Selected Channel:
1. Press and hold down the Push-To-Talk
button while turning the radio on, wait for
approximately 5 seconds then release the
Push-To-Talk button.
2. Use Scroll button to select one of the 8
frequencies.
3. On a Spirit GT+, press the Monitor button.
4. The current channel will flash, press scroll
button to change channel.
5. After the second channel is selected, press Monitor button again, current
frequency for second channel will flash. Figure 16.
6. Use Scroll button to select new frequency.
Exit Programming Mode - 3 Ways
1. Press Push-To-Talk to exit completely.
2. Allow the Menu time to expire (10 seconds).
3. Press Menu button to go to code programming.
Here is a link to the user manual: http://www.motorola.com/mdirect/manuals/Spirit_GT_User_Manual_E.pdf
How do i change the channel?
Selected Channel:
frequencies. Figure 16.
2helpful
3answers
Users Manual on how to use
Motorola Walkie Talkie Code and Channel Setting
  1. Push and hold On/Off button. It will tell you Code & Channel
Note: You are now in the change mode
  1. Change Code - Push the talk button till handsets match Code then push monitor button to accept
Note: You are still in the change mode so you can change Channel
  1. Change Channel - Push the talk button till handsets match channel then push monitor button to accept
  2. To check repeat step 1 then push on/off button
Motorola Talkabout Basic
I believe you do not need to hold the monitor button when changing channels
Push the talk button till you have the channel you want then push monitor button to accept
Hope this works
Top Universal Televison & Video Experts
vince
Jennifer Rock
Jennifer Rock
Are you an Universal Televison and Video Expert? Answer questions, earn points and help others
