... this is normal. All the apps that are pre-installed on the Apple TV 4th Gen come through the App Store and in order to activate them or your Apple TV the first time you start using them, Apple will request your Apple ID and password ...
This tip will help those who have forgotten their bios password not windows password. Your bios password is the password your computer asks for as soon as you power up your system. The windows password is the password needed to log onto your screen name. If you have forgotten your bios password almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. E.G. If the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin. Make sure to turn the PC off before opening the cabinet and resetting the jumper.
If it is a dual band router make sure it is still transmitting on 2.4htz as this is what most older tablets work on.then scan your networks , when it finds you network don't join but click far right arrow.what you need to do is forget the network because this will clear all previously stored passwords for that network that are kept on the device.then rescan , this time when you click join you can put in the latest password and it should be fine.
..an answer I have 11 m when i click 100k/200k/200k/400k table show up this message cold not join room:you are not authorized to enter the room.error code:RS1. i can play only 80 k down tables HELP
Wi-Fi settings determine whether iPhone uses local Wi-Fi networks to connect to the Internet.
Turn Wi-Fi on: Choose Wi-Fi and turn Wi-Fi on.
Join a Wi-Fi network: Choose Wi-Fi, wait a moment as iPhone detects networks in range, then select a network. If necessary, enter a password and tap Join (networks that require a password appear with a lock icon).
Once you join a Wi-Fi network manually, iPhone automatically joins it whenever the network is in range. If more than one previously used network is in range, iPhone joins the one last used.
When iPhone is joined to a Wi-Fi network, the Wi-Fi icon in the status bar at the top of the screen shows signal strength. The more bars you see, the stronger the signal.
Set iPhone to ask if you want to join a new network: Choose Wi-Fi and turn "Ask to Join Networks" on or off.
Join a closed Wi-Fi network: To join a Wi-Fi network that isn't shown in the list of scanned networks, choose Wi-Fi > Other, then enter the network name. If the network requires a password, tap Security, tap the type of security the network uses, and enter the password.
You must already know the network name, password, and security type to connect to a closed network.
Some Wi-Fi networks may require you to enter or adjust additional settings, such as a client ID or static IP address. You can type it manually by login onto the Belkin's network page using the browser and by copying the static and dynamic IP address.
Connects over the last Wi-Fi network you used that's available.
If no Wi-Fi networks you've used are available, iPod touch will scan for Wi-Fi networks and show a list of Wi-Fi networks in range. Tap a network and, if necessary, enter the password to join. Networks that require a password show a lock icon () next to them.
Option to manually enter your Wi-Fi network name/SSID (if the Wi-Fi network is configured not to broadcast or be displayed to the public). If necessary, enter the password to join.
When iPod touch is connected to a Wi-Fi network, the Wi-Fi icon () in the status bar at the top of the screen shows connection strength. The more bars you see, the stronger the connection.
Wi-Fi Settings
Turn Wi-Fi on or off. Choose Settings > Wi-Fi and turn Wi-Fi on or off.
Set iPod touch to ask if you want to join a new Wi-Fi network. When you are trying to access the Internet, by using Safari or YouTube for example, and you are not in range of a Wi-Fi network you have previously used, this option tells iPod touch to look for another network. iPod touch will display a list of all available Wi-Fi networks that you can choose from. Networks that require a password appear with a lock icon ().
If "Ask to Join Networks" is turned off, you must manually join a network to connect to the Internet when a previously used network is unavailable.
Choose Wi-Fi and turn "Ask to Join Networks" on or off. If you turn "Ask to Join Networks" off, you must join new networks manually.
Join a Wi-Fi network manually. Choose Wi-Fi, wait a moment as iPod touch detects networks in range, then choose a network. If necessary, enter a password and tap Join. Networks that require a password appear with a lock icon.
Make iPod touch forget a network, so that the device doesn't join it automatically. Choose Wi-Fi and tap the arrow () next to a network you've joined before. Then tap "Forget this Network."
Connect to a closed Wi-Fi network (an available Wi-Fi network that isn't shown in the list of scanned networks). Choose Wi-Fi, then tap Other and enter the network name. If the network requires a password, choose Security, tap the type of security the network uses, and enter the password. You must already know the network name, password, and security type to connect to a closed network. Some Wi-Fi networks may require you to enter or adjust additional settings, such as a client ID or static IP address. Ask the network administrator which settings to use.
Adjust settings to connect to a Wi-Fi network Choose Wi-Fi, then tap the arrow () next to a network.
1. Choose (Settings) then (WiFi) then (turn WiFi on)
2. Set iPod touch to ask if you want to join a new network:Choose (WiFi) and turn (Ask to Join Networks) ON or OFF.
Then you'll need to join a WiFi network (your D-Link for instance)
1. Choose (Settings) then (WiFi) then wait until your D-Link shows up in the list of networks.
2. Select your network and if you have a password for your router make sure you type it. (networks that require a password have a lock icon next to it) then tap (join)
Once you join a WiFi network manually, iPod touch will automatically connect to it whenever the network is in range. If more than one previously used network is in range, iPod touch joins the one last used.
When iPod touch is connected to a WiFi network, the WiFi icon in the status bar at the top of the screen shows the connection strength. The more bars you see, the stronger the connection.
Facebook will indicate this if you have previously attempted to use the same email address to sign up. Here is what you can do.
- Click on "Forgot your password?" link on the facebook homepage.
- Follow the process and they will send you a link in your email to reset the password
i'm new for the friendster...so how to join in friendster?thats mean i want to register.......plz help me has fast has a possible....pls change the on blue colour......
The Backdoor passwords are not determined by the laptop manufacturer - the backdoor passwords depend on the manufacturer of the bios itself. Is it an Award biosor an AMI bios etc?
AMI BIOS Backdoor Passwords:
AMI
BIOS
PASSWORD
HEWITT RAND
AMI?SW
AMI_SW
LKWPETER
CONDO
Phoenix BIOS Backdoor Passwords:
phoenix
PHOENIX
CMOS
BIOS
Misc. Common Passwords
ALFAROME
BIOSTAR
biostar
biosstar
CMOS
cmos
LKWPETER
lkwpeter
setup
SETUP
Syxz
Wodj
Other BIOS Passwords by Manufacturer
Manufacturer
Password
VOBIS & IBM
merlin
Dell
Dell
Biostar
Biostar
Compaq
Compaq
Enox
xo11nE
Epox
central
Freetech
Posterie
IWill
iwill
Jetway
spooml
Packard Bell
bell9
QDI
QDI
Siemens
SKY_FOX
TMC
BIGO
Toshiba
Toshiba
Toshiba BIOS
Most Toshiba laptops and some desktop systems will bypass the BIOS password if the left shift key is held down during boot
