SOURCE: hooked up dvd player to tv but no picture
Select Source button from your tv remote keep in AV mode than cheked if you have conected with yellow/red/white rca wire
SOURCE: i can't get the sound
Tries another set of cable,some time the cable have bad shorted at the cable neck flexable and not working correctly are the causes.Ur DVD/VCR player have a HDMI hub connection,used a HDMI cable for connection will work better for a HDTV.
SOURCE: I have no sound at
Hi,Would you pls check the connection that you have made between TV and DVD player..?
2xRCA (white+Red) will go to Audio IN sockets of TV in addition to 1xRCA Yellow video cable goes to "Video IN socket of TV..
if the connections are right than you must select the right source on TV ,as AV1 ,AV2 which corresponds to the cable input sockets of your TV.
Take care and please Remember to rate/vote for us to
continue for Helping out the Community :)
Testimonial: "Wasn't even going to check because I knew i put the the in the right sockets. Turns out, I put the red and white in the wrong red/white sockets! Thx!"
SOURCE: the sound on craig tv wont work
With your remote go to menu. Go to audio and make sure your speakers are turned on. murf427
