Nespresso U D50 Espresso Machine Color: Pure Black Logo
Rob Hutton Posted on Apr 11, 2015
Coffee pod stuck in machine - Nespresso U D50 Espresso Machine Color: Pure Black
John Jefferies
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Jun 03, 2015
John Jefferies
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
8063
Points
13
These machines are designed to use only Nespresso capsules. The UMilk, particularly, is susceptible to jamming if so-called "compatible" capsules are used, as the capsule is pierced electroncally, not manually as in most of the Nespresso range of machines.
Hope this helps, Rob.
Lavazza Jolie Pod Coffee Machine, the water in the dispenser leaks out of the machine, and no coffee comes out of the coffee pod
Here are some possible reasons why the water in your Lavazza Jolie Pod Coffee Machine leaks out of the machine and no coffee comes out of the coffee pod:
  • The water tank is not filled properly. Make sure that the water tank is filled to the correct level. The water level should be between the minimum and maximum marks on the water tank.
  • The coffee pod is not inserted properly. Make sure that the coffee pod is inserted into the machine properly. The coffee pod should be inserted all the way into the machine until it clicks into place.
  • The coffee pod is clogged. If the coffee pod is clogged, the water will not be able to flow through the pod and into the cup. Try using a different coffee pod or try cleaning the coffee pod.
  • The machine is not descaled properly. If the machine is not descaled regularly, it can build up calcium deposits, which can prevent the water from flowing through the machine properly. Try descaling the machine with a descaling solution.
  • The machine is defective. If you have checked all of the above and the problem persists, then the machine may be defective. In this case, you will need to contact Lavazza customer support for further assistance.
Here are some additional tips that might help:
  • Use fresh, cold water. Stale or warm water can affect the taste of the coffee.
  • Use a good quality coffee. Cheap coffee beans can make the coffee taste bitter.
  • Grind the coffee beans to a medium-coarse grind. A too fine grind can make the coffee taste bitter, while a too coarse grind can make the coffee taste weak.
  • Clean the coffee machine regularly. A dirty coffee machine can make the coffee taste bitter.
I hope this helps!
The lid won't open to get the used coffee pod out. It seems to be stuck.
Customer questions and answers for Bosch TASSIMO T10
answers.tassimodirect.com/answers/.../bosch-tassimo.../questions.htm?...
The TASSIMO T10 Single Cup Brewing System by Bosch brings the artistry ... the machine made some funny noises and now I cant open the lid to remove pod. ... When I went to remove the T-disc, the tassimo won't open so I cannot get it out.Missing: tas5542gb
Bosch Tassimo TAS4511UC Coffee Maker Open ... - Fixya
www.fixya.com > ... > Bosch Tassimo TAS4511UC Coffee Maker
Question about Bosch TASSIMO Coffee Makers & Espresso Machines ... colors, openthe lid, put disc with the cream in the machine and the green light won't come on, only the . ... Bosch Tassimo Tas5542gb Multi Hot Drinks Machine, Black.
Why has my Tassimo brewer stopped working?
www.coffeedetective.com/why-has-my-tassimo-brewer-stopped-working...
QUESTION: I have a problem with my Bosch Tassimo brewer. ... Now when I close the machine, I open it and remove that litte tin foil circle. ... Opened my new Tassimobrewer and won't brew and water dispenser leaking all over... an ... I have a problem with my tassimo coffee maker the lid wont lift up seems stuck any ideas ...Missing: tas5542gb
My Nespresso U is sending the coffee out where the pod drops down not through the spout
YOU MUST CLEAN THE SPOUT TO MAKE WAY FOR THE WATER FLOWN PROPERLY TRY RUINING SOME WORM WATER FERST TO CLEAN UP AND MELT THE STUCK COFFEE
What are coffee pods? Someone told me to use them in my coffee machine?
Some coffee machines have the option to either use ground coffee and filters or coffee pods. These are small, sealed containers that have the ground coffee inside. You insert the pods into the machine and click them into place. The machine pierces a hole and the water drips through. It's a much tidier way to make coffee especially if you don't drink a lot of it, so you don't want a whole jug full, rather just one cup at a time.
Feb 25, 2013 • Home
13helpful
Water is not being push through the pod. The water goes through just fine when there is no pod. Seems like a pump is not forcing water through.
When you insert a pod there is a sharp pin like piece of plastic that punctures the pod to allow water to flow into it. Right next to that puncture-pin there is one or more little tubes where the water is pushed out of. Take a paper clip and shove it up there and move it around to unclog it. There are most likely coffee grinds stuck up there. You should put a paperclip up there to loosen the grinds/unclog it and then run it without a pod. You may need to do this a few times but you should notice coffee grinds passing through into the cup with the hot water even when you run it without a pod for a few times. You will notice the water coming out faster and stronger; now you can use it as your normally would.
If this solution is helpful please rate/vote for me.
Thank you.
Capsules jammed fault 72
I pulled out the pod carousel, and reached by finger over the capsule tray hole. In there was a stuck pod. Once I go that out, I power cycled the machine and all was well.
2answers
Senseo stuck after using coffee pods that have "milk" built in....5 days later
I had the same problem. I waited for a while as the instruction says but didn't open. But, I got it open!!! by turning and slightly pulling a small plug behind the water tank on the backside. (remove the water tank then you'll see the little plug. see attached photos) I think it will let air in and vacuum seal get released. After it opened, I gently turned the plug back and push it in as it was. Now, it is running perfectly again. I just had a great coffee. :-)
58c3f6de-9c9e-437e-b419-0533bdf0a452.jpg562b78da-5cdf-43fe-afb9-546e2ba78530.jpgb5d600f7-721a-4b74-a954-ef849424bf28.jpg
Top Nespresso Coffee Makers & Espresso Machines Experts
Kolbrun...
Jay Finke
Jay Finke
Sulejman Sulejmani
Sulejman Sulejmani
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
