Flickering power at our house today. Clock panel is lit, oven lights work, but nothing else. Display shows OFF OFF and oven control buttons don' seem to work.
I should suspect the fuse or circuit breaker that is supposed to power the oven if turned off.
It could be nothing more than a power surge from a lightning strike somewhere.
Find the electric box and check it out.
If the fuse or circuit breakers panel is good, remove the oven and check for current at the wiring that goes from the oven to the fuse/circuit breaker box.
If all that tests good, you have a problem with the oven control.
It may be "toasted". (No good)
God bless your efforts.
In the power panel on your house. There are two circuit breakers with their handles joined.One of these breakers has tripped internally which will stop the heating elements but not the control panel or oven light since they work on 120 volts. Reset the breaker or replace it.
Becky, it sounds like you have either a failed ERC or Electronic control board (Y0315030) or a bad limit control switch (31933003). If it's the ERC it's likely bad relay(s). If your clock is powering up and you see the clock then that lets us know that you are receiving power to the oven. If it's the Limit Control, then you will need to replace that approximately $60. It's inside the oven and prevents the elements from getting hot if it breaks. If it's the ERC then you can have it repaired for $99.99 from The Repair Shack. The link for the repair service is: Repair Service For GE Oven Range Control Board Y0315030. Hope this helps!
You do not need the clock I removed it and wired the oven direct.The wires are easy to get at when the front panel is removed. If you look at the manuals on line they will guide you with the correct wires to use
HI,
Sounds like you need a repair person to check out the power to your display (clock), If your clock has power but will not display you could need either the transformer (low voltage 12 volts) or a ERC (which is the clock). Lately I have noticed transformers have been on the rise in several of these models. Also the transformer is alot cheaper than the ERC. If you can test this, you will find the connection you need is on the board as you tip the control panel, you will find the light blue wire bottom right of the control board. If you have 12 volts to the clock there, your clock is bad, in not your transformer has failed.
If you have never done anything like this call someone to help you, Be safe with electricity!!!
I hope this helps
Same thing happened to our Kenmore range and I found a solution on the web about fixing this problem on a fridgedaire range. It was to hold down the clock button for an extended time ~15 sec. It worked for our kenmore and hopefully for yours too.
Hey worken_man Try pressing the start button for about 15 seconds. If nothing happens its very likely that the transformer on the controller is busted. If you know how to get to the controller check the primary side (high voltage side) for open circuit. The easiest thing would be to change the controller and not fuss with changing the transformer
THE ONLY SOLUTION FOR THE BAD DISPLAY IS TO REPLACE THE CLOCK. I HAVE A JENN AIR OVEN TODAY AS A WORK ORDER TO REPLACE THE CLOCK FOR A FAILED DISPLAY.
FOR THE JGW8130DDB WITH NO POWER ANYWHERE, IT SOUNDS LIKE YOU HAVE A SUPPLY PROBLEM. MAKE SURE THE WIRING IS HOOKED UP WITH THE RED AND WHITE WIRES RECEIVING 240 VOLTS AND THE WHITE WIRE ATTACHED TO NEUTRAL / GROUND.IF THE OVEN HAS A BARE COPPER WIRE AND THE HOUSEHOLD WIRING ONLY HAS THREE WIRES, COMBINE THE WHITE WIRE AND THE COPPER WIRE TOGETHER AND ATTACH TO THE HOUSEHOLD NEUTRAL / GROUND .
UNLESS YOU ARE SURE ABOUT THE HOOKUP IN THE BREAKER/FUSE BOX, DO NOT GO SIMPLY BY THE COLOR OF THE WIRES.
