I put a new bored in it still is not working and after i let it sit for a min i get err and f1 code
The F1 error code on this model of Frigidaire range indicates that the electronic oven control board detects one of the following errors:
Failed oven temperature sensor probe
Shorted keypad
Internal electronic control board error caused by a power glitch or surge through the electrical lined
Failed electronic control board
The electronic oven control board will likely need to be replaced
Good Morning Paul, thank you for your post!
Based off what you have described your Frigidaire range, PLES389DCC, is providing you with an error code of "PF" and "F1" as soon as you turn it on. An error code of "PF" stands for power failure this could be a possible problem with your control panel or power cord.
The error code "F1" stands for a runaway temperature (overheating). This could be an issue with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would recommend performing a reset on your oven and you can do that by disconnecting from your oven for ten minutes. If you continue to have issues with the "F1" error code I would recommend having a professional technician out to your home for proper diagnosis and replacement of any electrical components. Hopefully this information has been helpful. -Matt
