Home Logo
p
paul ramos Posted on Apr 09, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
WHERE CAN I OBTAIN AN OWNERS MANUAL FOR HAMILTON CHIME MANTEL CLOCK - WHEATLAND
UsedClockPartsdotCom
Level 3:
  • Master 277 Answers
  • Posted on Dec 21, 2016
Master
Level 3:
Answers
277
Questions
0
Helped
146999
Points
4537
Here is a link to an online Hermle Service manual.
Hermle Service Manual UsedClockParts com
3 Related Answers
Anonymous
  • 15 Answers
  • Posted on May 10, 2010
SOURCE: I NEED THE INSTRUCTIONS FOR SETTING THE CHIMES/TIME ON MY WESTMIN
Manually turn the minute hand forward until the 16 westminster chimes sound and then the hour strikes. Then remove the minute hand (it will go on in four positions) and put it back on at the 12 o'clock position. The chimes should now be back into sync.
Fred
Anonymous
  • 5 Answers
  • Posted on Jun 05, 2010
SOURCE: Mantel Clock With Westminster/Whittington Chime: How to set the chime properly...
Pressing the red button advances the chime count by one. Continue to advanced the chime count until it matched the hour shown on the clock face.
Anonymous
  • 5 Answers
SOURCE: I have a Strausbourg chime mantel clock. It chime
each press of the red button will advance the chime count by one. Advance the chime count to match the face clock
2answers
I need help getting my Daniel Dakota quartz mantel clock to chime please?
Question edited for clarity and spelling 'danial' > Daniel.
Question moved to a Daniel Dakota category.
Basic information only. But make sure battery contacts are clean and tight and new fresh batteries.
https://www.google.com/search?q=daniel+dakota+mantel+clock+not+chiming
Strausbourg manor quartz Westminster mantel clock. Why did it stop chiming?
Source: Wikipedia
The full hour chime is followed by one strike for the number of the hour by Big Ben (E3) (one strike for one o'clock, two strikes for two o'clock, and so on). ... The mechanism then plays two complete sets of five sequences for each complete hour.
Source: PortableFireplace
Learn how to fix a mantel clock that chimes at the wrong hour. This simple fix will repair a clock that chimes at the wrong time. This can commonly occur when your mantel clock is laid down on its back and the timing is offset.
1 Thing You Have to Understand First On most clocks you can turn the minute hand counter-clockwise but SOME clocks are not safe to be turned in that direction. For this reason, it's best to only turn your minute hand clockwise just to be safe.
The Simple Mantel Clock Adjustment The easiest way to adjust a mantel clock chime is to move the hour hand to the hour that the chime is striking. Make sure that the hour hand shaft is not too tight or else it will not turn. Most mantel clock hands are friction held. DO NOT BEND YOUR HOUR HAND, loosen the shaft if it will not turn freely.
Once you have synchronized the hour hand with the hourly chime, adjust the minute hand to set the clock to the correct time by moving it forward (clockwise) around the clock face. Allow the chime to strike at every quarter hour strike.
Mantel clock Chime Adjustment When your mantel clock chimes the wrong number of times, your chime is not synchronized time of the clock. To adjust your mantel clock chime, proceed with the following step:
ADJUSTING THE HOURLY CHIME
  1. When your mantel clock chimes, count the number of times it chimes. This is what time your hourly striker is set to.
  2. Move the hour hand to the hour indicated by the hourly chime (count the number of gongs at the hour).
  3. Reset the time using the minute hand to the correct hour and the chime should adjust along with the clock hands as well.
ADJUSTING THE QUARTER CHIME
On most mantel clocks, you can simple remove the minute hand which is friction fit. You have to apply pressure on the tube and it will loosen. Once removed, re-install the minute hand at the correct time. From there you can rotate the minute hand to reset the time.
Mar 17, 2021 • Home
2answers
Looking for owner's manual for Seiko QQF142G mantel clock
You should be able to find one on seiko website
Nov 15, 2017 • Home
2answers
How do I stop the continuous hour chimes on a WESTMINSTER chime mantel clock ?
Is this a older type mantel clock or an electric. A older one has a small arm on the back of the wooden case just move it to it's opposite position and that should stop all chimes. A few times that small switch is on the inside but very rear. If it's electric it also should have a switch to turn off all chimes.
Feb 06, 2015 • Home
5helpful
3answers
Chimes do not chime due to winding too tight. Can this be corrected?
You need to remove the movement and use a tool to manually unwind the chime spring. This can be dangerous and can break you wrist, so you might consider having a clock repairman perform this maneuver. Then wind the spring about 1/2 way. If the chimes still do not operate, I suggest a good clock repairman.
Fred
4helpful
3answers
I NEED THE INSTRUCTIONS FOR SETTING THE CHIMES/TIME ON MY WESTMINSTER LINDEN MANTEL CHIME CLOCK
Fred
2helpful
2answers
I have a Strausbourg chime mantel clock. It chime 2 minutes late every 1/4 hour, how do i fix this. Rae
I lost directions to my clock, it takes two double a batteries for the chime but i dont know how to set it.
thanks
Top Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
