Sewing Machines Logo
Joyce Love Posted on Apr 08, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My serger is leaving marks on the fabric...little lines like from the feed dogs. I have cleaned, checked everything and cleaned again. I've also tried several different fabrics.
Chris Wetmore
Level 2:
New Friend:
  • Expert 190 Answers
  • Posted on Apr 08, 2015
Chris Wetmore
Expert
Level 2:
New Friend:
Answers
190
Questions
0
Helped
56282
Points
335
This sounds like too much presser foot pressure.
You can reduce the pressure on the foot by turning the knob on top of your serger counter clock wise
  • Joyce Love Apr 08, 2015
    Thank you Chris, that's what I thought too however, there is no knob on the top of my machine. I have tried finding info on how to adjust the presser foot and haven't had any luck yet. Thanks again!! :)
I have a Bernina 2000DE serger In the front feed dog is moving opposite of the back feed dog. I'm experienced at sewing machine and serger basic maintenance, but I am stumped. Any advice?
Sounds like the small plastic cog/gears have slipped, this rarely happens and usually is from pulling heavier fabric through the machine while trying to sew. The teeth on the feed dog grips to a portion of the fabric and is tugged out of the track of the path of the rotation...
Not necessarily an out of timing issue if they are rotating independently, but likely will take a tech to disassemble it and replace the part(s). They likely will need to be replace rather than just placing them back into place.
Hope the response is helpful..
My white sewing machine model 2037 foot dog is stuck down. My material won't advance how to fix.
www.fixya.com/support/t27227243-white_sewing_machine_model_2037_foot_dog
5 days ago - My material won't advance how to fix. ... The little white button on the lower right front of the machine is the button that drops ... If your machine doesn't feed fabric after doing what I've outlined then you ... check the feeddogs & see if there in the up position, if there not move the lever or knob to the up position SOLVED: Threading a bobbin for White sewing ...
1 answer
Jan 7, 2018
My Singer 9420 is not advancing the fabric. The ...
Sep 20, 2014
SOLVED: Baby lock serger will not feed, fabric ...
1 answer
Jun 14, 2012
SOLVED: Feed dogs won't raise up again
Mar 21, 2009
More results from www.fixya.com
1helpful
2answers
Brother CS6000i with setting 00 for straight line stitch is making a left curve stitches instead going straight.
***Your feed dog under the pressure foot seems to be pulling on one side a little harder which indicates wear. It is likely to solve the problem by replacing the feed dog.
***Before you do this try to lower the pressure on the pressure foot. If the material you are sewing is thick it will have an effect on the pull of the feed dogs. The material you are sewing that you sent appears to be jeans material. It looks like it is thick and somewhat slippery.
I have been sewing all morning. Suddenly the fabric does not feed everything is clean
Look at the feed dogs to see if they are rising above the needle plate at least 1 mm. If not rising lint may have felted between the feed dogs and the needle plate. It could also be the feed dogs have been lowered, or the height has slipped. If the feed dogs are above the needle plate turn the hand wheel and see if they are moving from the front of the machine to the back. If not it is a length adjustment. If this is normal the pressure on the fabric may be too low. Another problem may be the timing of the feed dogs. The feed dogs should rise above the needle plate when the needle leaves the fabric and descend when the needle comes down into the fabric. This requires an expert to fix.
Feed dogs not moving properly
it's very possible that the feed dogs are out of time & the machine would have to be serviced at a sewing machine repair shop
2helpful
When sewing with the brother serger 1034d, loops of thread stick out beyond the fabric-it is not nice and close like it's supposed to be. the settings from left to right are: 4,4,3,3. this is what my...
Can you wind the lower cutting blade to the right to cut less fabric and therefore fill out the stitching? On most sergers the lower blade position can be adjusted sometimes with a little knob or dial. You need to raise the top blade out of the way first, usually you put pressure onto it to release the spring holding it up against the lower blade, then swing it up to do this. Then wind the adjustment on the lower blade and move it to the right to cut less fabric then test serge. Your manual should give you more specific information on this and should be your first 'go to".
I would adjust my looper tensions to suit the fabric and width of the stitch I'm trying to achieve so yes, the settings you've been given are average tensions but its okay to vary these too. From left to right, I'd set 4, 4, 4, 4 and test serge again and see if this pulls the looper threads in against the fabric if moving the blade hasn't tightened up the stitching.
Sergers are more variable than a straight stitch sewing machine so its okay to move tension knobs a bit, just turn each a half number each time you adjust, then test serge and look at the stitch formation. Your needles tension should be fine at 4, leave them alone.
I'd suggest if you can find one, go to a "Getting to know your serger" type class as there is lots of techniques such as seaming on a curve, turning right angles, both inside and outside and making rolled hem edges that are very helpful serger skills to learn along with making adjustments and troubleshooting. Or go to you-tube and search some of these techniques for videos. Also www.sewing.about.com is a great sewing resource and Debbie has pages on sergers/overlockers here too.
When I'm starting a new dressmaking project I will spend 10 mins on the overlocker/serger, changing the thread colour to suit the garment, then test serging and adjusting the stitch tensions to suit the fabric. I have 4 cones of thread each in white, black, beige, grey, pink and pale blue and these threads will give a suitable finish on most fabric colours and prints. Then there is wooly overlocker thread, this is a fluffy thread that you can use for rolled hems as the thread relaxes once stitched and "fills" out the closely stitched edge covering the rolled fabric edge and is another whole area of fun to try out.
Often I'll just use a three thread to neaten the raw edges of a seam I will press open. Or I will assemble a whole knit garment using the four thread stitch, so much faster then stitching seams, then neatening. Jersey knits and sergers are made for each other.
As an aside the D on your machine model would denote "differential feed" too - briefly differential feed is adjusting the amount that the two feed dogs move under the foot and means you can "hold back" the fabric as it is stitched (0.5), or "stretch" it out (1.5 or 2 setting). Really handy for loose weave fabrics that stretch as you serge them, you can compensate using the differential feed setting. And in reverse, you can create a "lettuce" or wavy edge by turning the differential feed up.
I hope that this helps you out with your Brother 1034D and hasn't just confused you. Good luck.
1helpful
Will not feed the fabric
Here are a few solutions to check.
* Check your fabric to make sure it isn’t caught on something.
* Check your pressure foot to make sure it’s screwed tightly in place.
* Adjust the pressure of your pressure foot as it may be too light or too heavy for your fabric.
* Check your feed dogs for lint. If your feed dogs are clogged with lint, they're not gripping your fabric properly. Remove your pressure foot and clean out any lint with an old toothbrush.
* Raise your feed dogs if your machine has this function. They may have been inadvertently lowered.
* Check your stitch length regulator, If it’s set at “0” or a very small number, try switching to a longer stitch length.
* Change your needle, it may be damaged.
* Check your needle plate and make sure it’s securely in place.
* Use a “Jean-a-ma-jig” or a “Hump-jumper”. If you’ve been trying to sew over a bump of fabric, such as a thick jean hem, try using this tool (your local fabric store should carry it). It keeps your pressure foot level as you sew over the bump and gives your feed dogs something to grip.
I hope this helps
3helpful
3answers
Feed dogs on serger don't advance
I use my BLSE200 all the time and ran into the same problem just last week. After pulling out my hair in frustration, I finally realized it had to do with the stitch length. Something wasn't connecting after I adjusted the stitch length, so when I re-set the stitch length, it popped things back into alignment and the feed dogs started working again. *whew* Hope that helps!
Feed dog & auto threader problems.
Remove the needle plate and clean the lint from between the teeth of feeddogs, also around and inside bobbin case.
The switch for the feeddogs is to raise (normal sewing) or lower (free motion) and if there is no difference, the accumulated lint will have made a felt pad between the teeth forcing the feeddogs to stay down and present with the problem you describe.
When things go a little "weird", the common instinct is OIL EVERYTHING............DON'T DO IT !!! ....this is rarely the solution on its own account, and can make the servicing a great deal longer as the excess must be removed........little oil regularly, not a bucketful every 5 years is a better approach.
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
