Question about Xerox Office Equipment & Supplies
What is code u9 on the Xerox 5328? - Xerox Office Equipment & Supplies
3 Suggested Answers
SOURCE:
checkitright
  • 1362 Answers
SOURCE: xerox 5328 copier error
U9-3
Xerographic process problem.
The Exposure sensor detected low Exposure Lamp intensity. Switch the Main Power Switch off then on in order to clear the Status Code. Go to the U9-3 Xerographic Process Problem RAP
U9-4
The Main PWB sensed that the Toner Dispense Motor was not running. Perform 20-3 U Codes Clearance . Go to the U9-4 Xerographic Process Problem RAP
U9-5
The CSDC zero point was too high during auto setup. Perform 20-3 U Codes Clearance . Go to the U9-4 Xerographic Process Problem RAP U9-5 Xerographic Process Problem RAP .
Posted on Aug 11, 2008
  • 62 Answers
SOURCE: Rank xerox 5328 U9
if its a u9-1 code it is the lamp that is faulty. Sometimes it can be the connections either end of the lamp but normally the lamp itself. It will probably cost as much to fix as it would to get a new one to be honest
Posted on Dec 01, 2008
Message erreure U9
U9 in wc group is problem with HVPS. check charge & trf corotrons for leakage. isolate with removing charge or transfer corona each at a time.... U9 disappears; Reinstall HVT. Clean charge corona sawtooth & grid; tighten the grid on charge corona assembly.
Jan 23, 2011 | Xerox WorkCentre Pro 320/315 XL
My xerox pro 420 have U9 error?
The U-9 code means the main control unit/switch board has a problem, replace the board.
Jan 22, 2011 | Xerox 1 YEAR ON-SITE SERVICE AVAILABLE ON...
WORKCENTRE PRO 420 U9 CODE
Hello sir; The U-9 code means the main control unit/switch board problem, replace it.
Feb 07, 2009 | Xerox WorkCentre Pro 423 Copier
Rank xerox 5328 U9
Nov 03, 2008 | Xerox 5830 Copier
RE is the Xerox 5328 discontinued as a model?
Yes. It has been for some time. Xerox will not service it, but there are many reputable dealers that will. Parts are available and so is service. Just not by Xerox direct.
Oct 31, 2008 | Xerox WorkCentre M-24 Color Copier
Paper jam in xerox copier 5328
Specify the area of paper jam or the code on display that cud help isolate the problem quicker, it cud be a C or E code. Try to clear it with code 20 subcode 03, but state code on display
Oct 30, 2008 | Office Equipment & Supplies
U4 - 5328 xerox
Dear,
You can reset the code thru diagnostic code 20-3.Hope it will help you.
Aug 16, 2008 | Office Equipment & Supplies
Xerox 5328 copier error
U9-3
U9-4
U9-5
Aug 09, 2008 | Office Equipment & Supplies
XEROX 5328 COPER
Total weight is about 200 pounds. But, that machine comes apart.
You can take off the thumb screws and disconnect one plug and lift off the document feeder.
The machine processor separates just above the tray 2/3 module, also the tray 2/3 module separates from the stand. So you can make is much easier to move by taking it apart. Nothing is bolted together, just sits one on top the other.
Jul 07, 2008 | Xerox WorkCentre M-24 Color Copier
65 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
