Question about Jura Capresso Impressa E75 Espresso & Coffee Maker
Open tap - filling system - close tap
I'm in the same loop , i have an ENA5 jura..
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 60 Answers
Try using warm water in the watertank, important that the water is not too hot, it can cause leakage in the o-rings in the fluidsytem.
Repeat the procedure a few times, if nothing helps, turn off the machine and wait 1 hour and try again.
If you can`t get around this message, then the flowmeter needs to be changed.
Posted on Jul 12, 2009
Using hot water with descaler works even beter then just hot water. I had to repeat the filling process many times with hot water with descaler before the flowsensor started working again
Posted on Apr 10, 2019
We have the Impressa F60 and ran into the same problem. I finally called Jura support. The tech told me to remove the grounds tray, and to take a dry paper towel and reach way back inside and wipe out the grounds. On my model there is a plastic flap that you have to go past and wipe the top of the chamber. Anyway, I was HIGHLY skeptical that this would work, but it did! Now, every time I empty the grounds I wipe this out. If we forget, the open tap issue eventually comes back.
Posted on Jun 05, 2010
SOURCE:
Tools needed to repair jura capresso
theres many places that i have found that provide the screwdriver to open the jura. before you could only buy them in a single with either a t handle or key chain loop. those are made from aluminum and last for about opening 3 screws and then they break. recently i have seen that single screwdriver is now made from crv steel. normally you will need 3 screwdriver trox oval and philips. they be purchased on ebay or amazon. you can get them in a set also just search for newelectronx 102. that is a screwdriver set that includes the oval phillips and trox. which is basically everything you'll need.
Apr 19, 2014 | Jura Capresso F8 Espresso Machine
How to open for cleaning jura ena5 coffee machine
The question is, how to open the machine? I found elsewhere one should unscrew the back logo, but it is slippery. Seems like a special tool would be needed, but I did not find it.
May 06, 2012 | Jura Capresso Jura Ena 5 2Cup Coffee Maker
I keep getting open tap and when I open tap, its says close tap. I have unplugged it and it still continues the loop.
I have had this happen when trying to change filters and go through the rinse procedure. For me the problem was that the little hole on the frothing wand was plugged. Once I cleared the little chuck of dried milk everything started working again.
Dec 28, 2009 | Jura Capresso Impressa F7 Espresso Machine
Jura Capresso Impressa E75 Espresso & Coffee Maker Logo
2,077 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
markybean
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
