Cars & Trucks Logo
Sandra Holland Posted on Jun 29, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
94ford probe won't start
Car would not start. The only way to get it to run was to push start it. Very easy to start with a pop of the clutch. Had battery checked fine bought a new starter and installs it, still won't start. Son ran a toggle switch from starter to inside of car and that worked fine, someone tried to steal car and left the toggle switch in the on position and burn out my starter but now it won't even start when we push start it. Can anyone help me.
Jeff Armer
Level 3:
  • Cars & Trucks Master 15,575 Answers
  • Posted on Jun 29, 2017
Jeff Armer
Level 3:
Answers
15575
Questions
Helped
7108725
Points
73899
Well Sandra , the thing to do would be to get it to turn the engine over with the key , Then diagnose the no start problem . Look at a wiring diagram (do you know what that is ?) When you turn the key to start , the electrical part of the ignition switch sends B+ voltage to the starter interrupter relay through the clutch switch to the starter motor solenoid . Testing the electrical circuit with a DVOM - digital volt ohm meter with the help of a wiring diagram ,so you know where to test is the proper way to diagnose the problem . Not guessing ,an rigging the stuff . You can find free wiring diagrams here http://www.bbbind.com/free_tsb.html
Enter vehicle info. year , make , model an engine ! Under system click on engine ,then under subsystem click starting . Click the search button then the third blue link .
Electric Testing Techniques You Need to Know
Do you know what a relay is ?
VEHICLE RELAYS Testing from the relay base
VEHICLE RELAYS Operation Diagnosis
If you look at the wiring diagram you will see the relay is controlled by the CPU - engine computer .
How to voltage drop test starter motor circuit
I have a 1993 Suzuki swift 5 speed. My son hit a dip in road hard it killed motor. Unable to pop the clutch
motor still dead, (my other shoe drops)
pop clutch, what does that mean.?
clutch is bad? what?
if you cant crank engine in gear, the clutch is bad.
hint, it can be the clutch actuators not the deep inside parts.
or does cant pop, mean
Car will crank but not start. so I pushed the car and popped the clutch in 2nd gear and it will not start either.
please post with all symptoms, pretend net bunny here are blind.
smart bunny's but totally freakn blind.
2answers
Can an automatic with a dead started be started?
I think your asking "can an automatic be push started?" The answer is No, a manual transmission can be push started by popping the clutch. ...
I was driving my 99 neon and heard a pop. The clutch peddal went to the floor and i cant get the car to go into gear
the hydraulic slave cylinder may have let go and will need replacing. its also possible that the clutch pressure plate broke or the clutch plate. you don`t say how many miles you have on the clutch. you also don`t say if it won`t go into gear with the engine running, which indicates clutch, or with the engine off.
1helpful
My car will not go into gear unless its started and already in gear. Ill pull it outta gear and won't go back in while running.
Your transaxle will have to come out & new parts installed,
like synchro rings
You should be able to push in the clutch & shift thru all
gears nice & smooth,with no engine running.
That said I wouldn't rule out clutch issues also,but not
for the shifting issues.
I started my car, drove it and parked then shut it down. car would not start turning key. nothing would happen. pushed it a bit then popped it in 2nd gear as it is a 5 speed and it runs fine. car has a...
Sounds like the neutral safety switch is going bad. Next time it does this to you with the engine off and the selector in neutral pop the clutch by pushing it down all the way then letting your foot slide off to the side so it's pops up and then see if you can start it. If this works you need to adjust the clutch and or replace the neutral safety switch on the transmission.
Ran out of gas on 89 Acura Integra, car won't re-start
pull tow the car and pop the clutch to jumpstart. when u run out of gas sometimes u get an air bubble in the line and it has to be pushed up to a certain speed then pop the clutch in second or third gear and it should start.
3answers
7helpful
2answers
Clutch pedal went to the floor but did not come back up. Heard something 'pop' when pushing in clutch last night. Got home, then tried to start car this morning and clutch made a 'pop' sound again when...
there is a plastic clip that connects the clutch pedal to the rod that goes to the master cylinder, chances are that it let go. Bad thing is that it is only available from GM along with the rod. It is around 50
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
