Karcher 2500 PSI Pressure Washer Logo
Les Byquar Posted on Apr 05, 2015
Pull the trigger and water surges - Karcher 2500 PSI Pressure Washer
2 Related Answers
Anonymous
  • 13 Answers
  • Posted on Oct 20, 2012
SOURCE: water surges when you pull the trigger
If you have not flushed all air out of hoses prior to starting motor this may be the first symptom. If the water pressure from the spigot is competing with the clothes washer, shower etc. there may not be enough pressure to supply the demand of your pressure washer. A gauge attached to the spigot can give you a gallons per minute reading or take a five gallon bucket and time how long it takes to fill the bucket. ie: if the bucket fills in 2 minutes you have 2.5 gallons per minute. You may need this much to get un-interupted pressure for a 2400- or 2500 unit. Most residential properties are pipe sized from 3/4" pipe at the water main spigot at the front of the house down to a 1/2" pipe size at the rear of the house to maintain pressure.
Cliff J
  • 90 Answers
  • Posted on Jun 01, 2015
Not enough water feed would cause pump cavitation. It sounds awful.
It sounds like you either have an engine that is revving up and down which will cause the water to surge. This is most likely a dirty carburetor. You should notice a distinct increase and decrease of the engine noise.
Or you have one or more check valves that are not seating properly. In this case the engine noise will be pretty constant but the spray out the wand will pulsate.
I have a troy bolt power washer and it won't pump
You need to give more information. Does the motor stall when you squeze the handle? Does the spray surge and the motor run well? Does the spray surge and the motor surge as well? Does water come out of the bottom of the pump? Does nothing come out of the spray gun when the trigger is squezed?
All of these symptoms point to different problems.
What does your machine do?
Oct 24, 2014 • Garden
Hi I have a homelight UT80546 pressure washer that stalls as soon as I turn the water on. I have replaced the pump with a brand new one that does the same thing. It also has a new carburetor, fyi
My neighbor has one that will do the same thing if the inlet water pressure it too high. I don't know if there is supposed to be a bypass for this water until the trigger is pulled or not. But once the trigger is pulled on the wand the problem goes away. So if you just pull the trigger when turning the water on that should solve your problem.
Oct 02, 2014 • Garden
Why does my pressure surge
Common problem across brands. When you spray water the drop in pressure triggers the motor to take the hose pressure ~ 30 psi and boost it to ~ 3000 psi. Water coats these parts with calcium (hard water) or other junk and water contains bacteria which causes slime and scale. Once that pressure switch / valve is sufficiently clogged it doesn't move smoothly so it can fluctuate between sending a yes / no signal about whether you are squeezing the trigger or not. This causes the pulsing.
EZ test: take the the tip off the wand, start the unit, squeeze trigger - should run continously with no problem. If it does for sure you need to watch a video on dissembling and cleaning the valve body. It is not hard but you must work carefully to avoid losing parts especially springs and take digital pictures to record the order for reassembly.
Karcher K5.7 surging
Maybe the unloader valve needs to be adjusted. it controls pressure and if a unit is surging while on, I would look there.
Sep 08, 2017 • Garden
1helpful
I just bought a hoover steam vac model F5914900 and the clean water tank is leaking. I tried pressing the clean surge button and the trigger button that was suggested by someone else but it won't
Go to Hoover.com and find a local Service Station. They will replace it at no charge. MUST be a warranty location to get it free. Take your sales slip with you.
I have used the McCulloch (FH180A) three times over the course of two years. On my fourth use the pressure washer just surged on and off and I would get a tiny spray from the gun each time it surged. In...
Sounds like the problem could be low input water flow or pressure. There could be crud on the intake where you hook up the garden hose, there could be some other sort of blockage. Try hooking it up to the hose and pull the trigger (with the power switched off) and wait to see if water comes out the tip. Also look at the tip(s) themselves. sometimes a piece of crud gets into the hose and then clogs the tip.
Washer surges when trigger pulled
Check that your are getting proper water pressure. Also check filter going into the machine where the hose connects sounds like the washer is not getting enough water pressure.
Hi i have inherited a karcher kb9040.it has only been used 4 or 5 times so i dont realy know how it should sound when. water is suplied to it it surges when you pull the trigger you only get the presure of...
hi there!
when you got as good as pipe pressure,you need to accelerate the speed motor to have a good pressurise water for your purpose,the pressure washer has a surge regulating valve as you trigger water gun the pressure blow up,as long
as you pull the trigger on the pressure build up pressure it has also equipt with pressure switch to regulate pressure and for safety purpose.you can also adjust the nozzle by rotating gradually to slim the pressure water out put.have a nice day,don't forget to rate me.thank's
Apr 20, 2009 • Garden
1helpful
When motor is at idle speed it surges
Try a simple test. It is ok to run the pump without water for a short time. Check idle speed without water in system to see if enginet surges. If it does not surge, then most likely the unloader/ pressure valve is causing the engine to surge when in the unloaded state. Life of unloader /pressure valve is shortened by letting system bypass for long periods of time. Enjoy
Nov 22, 2008 • Garden
Top Karcher Garden Experts
Sean Wright
Sean Wright
Sulejman Sulejmani
Sulejman Sulejmani
ZJ Limited
ZJ Limited
Are you a Karcher Garden Expert? Answer questions, earn points and help others
