Need instructions for setting armitron 40/6735
This should help with the 4 buttons:
Push the button Lower left and hold it for 2 seconds and you
will see a number flash. This is for the alarm setting.
Push the same button again and a new screen with the time
comes up and the seconds are flashing.
Push the top right button again and the minutes will be flashing.
Push the top right again and the hours will be flashing
Push the lower right one time and the time moves ahead 1
hour
Push the lower right again for the next hour and the time
moves again. Do this as many times as you want to change the hours. Each time
you reach 12:00 the screen will change the “A” and “P” to tell you if you are
in AM or PM. Time.
You can set the minutes in the same way as you do the hours
by pushing the lower right (set) button. The when done push the lower left to
stop the set-up
After you set the time or the alarm, push the lower left
button again to stop the set-up.
