Question about Franke Coffee Makers & Espresso Machines
Hi, my Franke Flair does not respond when I push any of the buttons to make coffee, water, milk etc. it just displays the 'SELECT PRODUCT' message. The rinse, clean and descale buttons all work.
  • 1 more comment
  • rezasagha
    rezasagha Sep 15, 2018
    i have same problem
  • rezasagha
    any other solution?
  • Anonymous Jan 30, 2019
    I also have the same problem. The technician says it could be the motherboard... Weird!!! then he quoted me to pay 900USD to replace the motherboard... I hope I can get a more sensible and reasonable answer from anybody???
    Sergeant:
  • 242 Answers
Unplug unit to reset the settings completely...If you have the same problem call manufacturer to save time...
Posted on Apr 05, 2015
3 Suggested Answers
SOURCE:
  • 4 Answers
SOURCE: Franke coffee system, always same error message ''fill water tank''
What you would have to do is take the side panel off to get at the solenoid. It is probably sticking closed and not letting the water fill into the boiler.
Posted on Mar 21, 2009
SOURCE: system fill message
I had a new Flair. The technician directed me to use a full bottle of the descale fluid and cycle the rinse button several times then to let it rest for 15 minutes or so. This was repeated for several iterations....It worked and I'm having no problems.
Posted on May 13, 2011
No milk and steam dispensing from Franke Flair coffee machine
I am a Franke technician. After and possibly during the descale, because probably you haven'nt done it in a long time, steam was able to escape through the fittings as the limescale damaged the silicone rings beforehand. The steam damaged the klixxons or the thermoblock itself. You will need one of us unfortunately....
Feb 17, 2018 | Franke Coffee Makers & Espresso Machines
My Franke Flair machine has water in tank but get message "fill water tank". Cleaned tank thoroughly, tried plugging and unplugging machine too.
The water tank has a float magnet in the left hand side of the tank. A reed switch is mounted inside the machines right hand panel which senses if the tank is empty. If you remove the tank and fill with water and the display indicates fill tank. The sensor may have failed. Or the float has stuck in the down possition.If the display indicated filll sytem and or rinse. Then the sensor is fine. The next stage is to try rinsing . If it keeps saying filll system or rinse then there may be a blockage in the tank. Or the flow meters have failed. This is assuming water is being dispensed from the water arm etc . If no water is being dispensed and this time assuming you can hear the pumps running. Then there possibly be a blockage in a thermoblock. I could go on for ever guessiing based on the info you discribed. If any more info is required please say
Jul 20, 2017 | Franke Coffee Makers & Espresso Machines
I have a franke flair coffee machine when you switch it on it reads on the panel please wait and will not complete the switch on. Any help thanks
DESCALING The Saphira has an integrated descaling program. The procedure takes about 60 minutes. Once started, the descaling procedure may not be stopped. • When acid-containing descalers are used, immediately remove any splashes or drops on sensitive surfaces, particularly from natural stone and wood surfaces. Also, take the appropriate safety precautions. • Turn off the Saphira by pressing the "ON/OFF" button. • Press the button "Descale" until an acoustic signal is heard. • Display: EMPTY DRIP TRAY (Fig.1) • Display: INSERT AGENT IN TANK • Display: PRESS DECALCIFYING Dissolve 2 DESCALING tablets completely in 2.5 cups of water in a vessel and pour the mixture into the empty water tank. Place a sufficiently large container under the steam tube and the coffee delivery outlet. • Press the Descale button • Display: UNIT DECALCIFYING • Display: PLEASE WAIT • An acoustic signal is heard. • Display: EMPTY DRIP TRAY (Fig.1) • Display: FILL WATER TANK • Display: PRESS DECALCIFYING • Press the Descale button • Display: UNIT DECALCIFYING • Display: PLEASE WAIT • An acoustic signal is heard. • Display: EMPTY DRIP TRAY • Display: CLEAN CONTACTS
Good Luck Mikey@espressomachineexperts.com
Dec 22, 2010 | Franke Saphira Espresso & Coffee Maker
How can I get different size lattes and cappucinos with my Franke Flair? all it gives me is a shot size serving...
enter programme button.push and hold for 5 secs.machine will show def product. press programme again to confirm.select product comes up on screen.press the product you want to adjust eg espresso.now use the + and - buttons to scroll through the espresso setting. if you want to adjust anything in the settings, you need to press programme. then make the adjustment with the + and- buttons then press enter when finished the actual adjustment .once finished with the espresso and happy press exit button.repeat the process for the next button. you can down load a manual at franke .com
Aug 17, 2010 | Franke Saphira Espresso & Coffee Maker
Poor frothing
You need to check (or replace) the air-intake nozzle which is located inside the coffee outlet. You will sure loose the good froth if that part is not clean or replaced. There should be proper amount of air input to produced the proper froth.
Rihel Calma Philippines
Aug 22, 2009 | Franke Saphira Espresso & Coffee Maker
System fill message
Then it is a problem with the flowmeter. This needs to be changed, please contact your local dealer.
Aug 13, 2009 | Jura Capresso Impressa S90 Espresso...
If you need a Franke trained coffee machine engineer to repair, service or for training, i can be there within 24hours, Email me for any questions great prices! 50mile radius of CV21 3SH
Hi
I have just bought a Franke Flair coffee machine second hand. It looks like new and the seller said it was in good working order - however it does not have the grinder blocker and I think we need one. I wouldn't mind also getting the once over from an expert and then maybe some kind of ongoing contact should we have problems with it. What are your rates?
Jun 15, 2009 | Franke Saphira Espresso & Coffee Maker
Mar 20, 2009 | Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
334 people viewed this question
Top Franke Coffee Makers & Espresso Machines Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
jonathan Hanson
Level 1 Expert
Are you a Franke Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
