SOURCE: northstar pressure washer randomly gives pressure
Hi:
You need to find the bypass (unloader) valve and grease it with a good waterproof grease. Sorry, I cannot find a pic for you
SOURCE: my electric stea pressure washer wont ignite
There can be multiple reasons for a burner not to fire.
Here is a link to a troubleshooting guide for hot water pressure washers.
link
SOURCE: I have an older Landa Pressure Washer. The burner
Check for 12V at the igniter connector with the unit running. If you have 12V and no igniter it may be stuck or bad. Thrun the unit off and read continuity across the DISCONNECTED igniter plug / terminals to the igniter. No resistance = open igniter.
If all of the above checks out your going to have to look at the fuel pressure switch to see if it closes and passes 12V to the igniter.
Before you give up... Check the fuse.
Landa's website is www.landa.com
You will have to select a local dealer for parts.
Thanks for using FixYa!
Kelly
SOURCE: Northstar pressure washer needs new hose
Need to know what country you are located in and if you want a 15 foot hose or 25 foot or 50 foot hose. The reason is We have to know where you are going to buy it and if you have a dealer that that is local or not. it's a 2500 PSI hose so the hose has to be a minimum of 3200 PSI You can also have hoses fixed at local hydraulic shops in the U.S. in the local phone book, they can make up the hose you need if you take it to them let me know.
