Apple iPad (16 GB) WiFi Tablet PC Logo
J
James William Posted on Apr 04, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can't receive email to my [email protected]
For the past few days I stopped receiving emails to me eclectik email address thus forced me to create a new email address
Mark Carey
Level 2:
Sergeant:
  • Apple Expert 141 Answers
  • Posted on Feb 13, 2019
Mark Carey
Apple Expert
Level 2:
Sergeant:
Answers
141
Questions
Helped
192067
Points
739
For SBCglobal email related errors and issues, the easiest solution for troubleshooting is to reach SBCglobal Email technical support service. Their experienced support team offers an instant solution and help for email setup and password related issues.
Dial directly toll-free number 1888-315-9712
sbcglobal email support number [Toll-Free 24x7]
Can't receive email to my eclectik@sbcglobal.net - sbcglobal-email-support-c0upx0fza2yxxd4n5y5ulnrc-4-0.jpg
vcudnik
Level 1:
Problem Solver:
  • Contributor 16 Answers
  • Posted on Apr 07, 2015
vcudnik
Contributor
Level 1:
Problem Solver:
Answers
16
Questions
Helped
3101
Points
30
If the settings on your ipad haven't changed, the problem is with sbcglobal.net -- test by logging in via webmail at their site. It could be something as simple as them forcing a password reset, and you not getting the message. If the old settings work with a new account, that's the most likely scenario.
My tablet has stopped receiving emails
I assume you have already verified internet connection. Depending on your device and email client, a few different issues might be causing your problem...some email clients require you to login after certain lengths of time. Perhaps logging out and back in from your device will fix this. Also, there is a push email or pull email functionality on many devices. If yours somehow became set to pull, it will only download your email messages when you ask it to. It would be helpful to know your device and email service for a more directed answer.
I m hving problems receiving nd sending emails sys unable to open email server
I don't want to sound crass Olive but did you forget your password. Is this a new tablet and are you connected to internet? Thank you and leave me some feedback please.
I have just updated my iPad in settings and now don't receive emails. Can see on my iPhone that I have some
This is and ongoing problem with the new OS's. If you delete the email account and redo the email setup this usually helps. Ex. If you have a Optimum (Cablevision) email acct you need to use mail.optimum.net NOT mail.optonline.net cause Apple is not recognizing the old server names. So check with your email provider if the server names to setup have changed. I know that changing your email address can be a pain but if you go to a GMail email acct this will solve a lot of the problems that occur when using cable provider email accounts. Also there is a software that will notify all your contacts that your email has changed that you can implement if you choose.
Im stuck in the 60's/70's! But Im trying! Why cant an android tablet and an I pad tablet email to and from each other?
There is no reason they shouldn't be able to. If they both have the same email address configured for them, then you would get the same email on both devices. If they have different email addresses configured, then they would only receive the email for the address configured on the device.
When the recipient is not receiving my emails!
First, always double check the intended recipient's email address. Next, email yourself with an alternate email address to verify that its not a setup issue on your iPad. If you don't receive it, then check that you are logging into your email service properly. If everything checks out on your end (you received the email you sent to yourself and their address is correct) then I would suggest its an issue with the recipient's service and they need to make sure they are not filtering you out.
Blueyonder email
Contact their supports at: http://www.blue-yonder.com/en/contact.html
Have not received emails for a week
1. Are you connected to wifi?
2. If you are, proceed to third step
3. Check that your email address and password are entered correctly for your account.
4. If you are still not receiving emails, Google the default port numbers for your email provider and check them against the port numbers in the Mail app settings
Email account does not send emails
Email accounts can be hard to sort out if you don't know what you are doing. Have you thought about changing your email address to someone like Hotmail, Google, Yahoo.
It is easy to register with them and you should need to do anything for them to work properly.
What sort of PC are you using? It will help if I know so I can answer the question about copying and pasting.
With a laptop you put your pointer to the start of the text you want to copy and then click on the left side of the trackpad and keep pressure on and move from left to right until all the text you want to copy is highlighted. You can now let go of the trackpad and press you Command key + C or go to the menu bar and select Edit and then Copy. The url is now copied, now to paste you put the pointer to where you want the url to be and simple press command Command key + V (on a Macbook) or go to Edit again and select paste from the drop down menu. You should now have copied and pasted your url?
Hope that is of help.
2helpful
2answers
How to reset my password on my google account
Occasionally Google Gmail user may want to reset the password which used to login into the Gmail account via web, POP3 and IMAP as the original password has been forgotten, or misplaced. Gmail credentials integrates and bases on Google Account. So changing the password for Gmail will also change the password for the associated Google Account.
In order to reset and change the password of Gmail and corresponding Google Account with the affected Gmail email address, follow these steps:
  1. Go to https://mail.google.com/ (related: other Gmail URLs).
  2. Click on I cannot access my account link.
  3. Click on radio button of I forgot my password, and then click on password recovery page link (or you can go directly to the link above).
  4. Enter the username for the Gmail or Google Account in the field provided.
  5. Enter the captcha letters as shown in the image on screen.
  6. If you never login to the Gmail for the previous 24 hours, a secret question as set in the Google Account will be presented. Answer the question with a correct answer in order to be able to reset the password.
    If you're unable to answer your security question and the account has a secondary email address configured, a link will appear at the bottom of the secret question results page. Clicking on the link will has a password reset email message sent to the secondary email mailbox. After receiving the email, follow the link to reset the password.
    If you have login to Gmail in the preceding 24 hours period, the password reset email will be sent immediately instead. Follow the link to reset the password. If you don't have a secondary email address, or if you no longer have access to that account, repeat the steps above after 5 days. At that point, you'll be able to reset your password by answering the security question you provided when you created your account.
  7. If you cannot remember the answer to secret question, cannot answer the secret question correctly and do not receive password reset email in secondary email account, try to contact Google for help.
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
