This web cam shuts down all internet programs when I turn it on
This web cam works on all non internet programs but shuts down any program with internet like on Skype(TM)everything works fine till I start my video how do I fix my web cam? NOTE: This webcam is built in.
1( test for overheating , check the fan if is functioning 2(power supply test the power cord, and see if the receptacle is o.k put some lamp and see if is working, if working, the problem can be adapter /or power supply. 3( Virus, some virus introduce from web internet, and cause to shut down, use the AntiVirus and instal some program for Web Security like Norton, etc. God bless you
Under programs, there is a dell web cam program,there is also a dell web cam help file,if you install skype (a free web cam communication program) it will automatically turn on and off the web cam as the program starts and exits.there are also other dell web cam programs that will let you adjust ,and take snap shots called web cam console and dell webcam manager
Go to device manager uninstall the driver for the web cam then after that download the latest driver for your web cam in the support website of dell. Then, install it if that doesn't work. Access BIOS of your laptop that will be f2 on the start up of your computer check if the web cam is detected. If it is reinstalling the application of the web cam can help, If it is not detected and after you've tried the all the things that I've told you it's either you end up erasing everything on your computer or replacing the web cam which is integrated in your LCD.
There is a program that is failing to shut down in general, which is delaying the computers ability to shut down.
The next time you shut down, make sure you have no programs open. Then, while attempting to shut down, wait until Windows pops up window asking you to close a non-responsive program. When it does, take note of the program that it mentions, then close it and see if Windows shuts down. Note: sometimes this takes a really long time.
Try re-installing the non-responsive program and see if your computer can shut down normally again.
your web cam being unable to cope with a high frame rate ( this is unlikely)
your internet connection speed is low
your computer is running to slow to prosses the web cam information
Solutions
if your webcam cant handle high frame rates, then the only solution is to buy a new, higher quality web cam
if your connection speed is low, then close down other programs that use the internet, eg internet explorer or multiplayer games
if your computer is running to slow to prosses the information, then close down any unnessesery programs, for example games, internet, or even word and exell
good luck, please take the time to rate this solution thanks
The problem could be the speed of the internet and also could be the computers memory. Try to reduce the size of the web cam window and also the speed and drop down the quality in the messenger. Try to use only messenger when using web cam not other programs. If this doesn't work try to reinstalling the yahoo messenger.
This sounds like a power supply issue whereby your computer is not suppling enough current to the web cam for it work and therefore the power supply shuts down rather than harming your system.
