I have the janome MC200e, the last couple days my machine has been freezing mid pattern, I have had to restart it and forward to the point in the pattern I was to finish. Last night it shut down on me, when I tried to restart it it said RomRestoreMode Very 1.0 Error!! Please help. Thanks
SOURCE: Janome Customizer 10000
There are different programs for 350E. I think, you was buy program different.
SOURCE: We have a Janome sew precise machine that we bought new about two
I had the same "problem" with my new machine. I called Janome's customer service and they told me the stitch length dial needs to be on S.S. I did that and it worked!
SOURCE: Cannot get a straight stitch
Please check the top tension as well and rethread. I had this problem and after doing the above, everything worked perfectly. Thanks.
SOURCE: My Janome 10000 stopped in
Janmore10000 Stopped Embroidering thenstopped everything just shutting off.
If it is getting no power at all, it is probably a fuse. Thefuse is located in a little black box underneath the base of the machine, butit is NOT an easy job to take the box out, disassemble it, replace the fuse,and then reassemble the whole machine. But in your comment you mentioned that there is power tothe machine that means its not fuse problem.
It stopped embroidering in the middle of a project. the handwheel would notmove at all this means that it wasthread jam. Also check the carriage carriage if it does not move to the rightor left and gor stuck in one position or hardly moving a bit then it is out of calibration.
if your machine is outof calibration it will need to recaliberate . Something is like forcing theneedle through a thread jam would cause this. This is not an expensive repair.But a time consuming repair. Its advisable to get it done by service center,
click this linkdirectly to get the support center help
http://janome.com/index.cfm/ContactUs
This will help. Thanks please keep updated. please dorate the solution positively .thank you for using fixya.
SOURCE: Help. I inherited my mother's
Hi karen!!!
Here is a link on how to thread a janome sewing machine.
To see the result just click the link bellow...
http://blog.ginakdesigns.com/2008/02/20/janome-sewing-tutorial-2-threading-the-machine.aspx
That link will definitely help you with your problem but if not please add a comment.
thank you for using fixya..
Maybe email or call their support:http://janome.com/en/support/
