Hi schoeller:
Hope this helps.
Replacing the transfer unit when it is not at end-of-life
If you replace the transfer unit when it is not at the end-of-life, for instance if it is defective,
you will need to reset the transfer unit count and then calibrate the printer, through the
control panel.
To reset the transfer unit count, do the following:
1. Press MENU to enter the MENUS.
2. Press down arrow to highlight Configure Device.
3. Press check to select Configure Device.
4. Press down arrow to highlight RESETS.
5. Press check arrow to select RESETS.
6. Press down arrow to highlight RESET SUPPLIES.
7. Press check to select RESET SUPPLIES.
8. Press down arrow to highlight NEW TRANSFER KIT.
9. Press check to select NEW TRANSFER KIT.
10. Press down arrow to highlight YES.
11. Press check to select YES.
To calibrate the printer, do the following:
4. Press down arrow to highlight PRINT QUALITY.
5. Press check to select PRINT QUALITY.
6. Press down arrow to highlight CALIBRATE NOW.
7. Press check to select CALIBRATE NOW.
8. Wait for the printer to calibrate.
The transfer unit count is reset and the printer is ready to use.
To reset the fuser count
5. Press check to select RESETS.
8. Press down arrow to highlight NEW FUSER KIT.
9. Press check to select NEW FUSER KIT.
The fuser count is reset and the printer is ready to use.
Hope this helps.
