The printer "says" to be offline and won't print. Cables are working (tried on another CLP-325). Already tried to change its status from the Preferences panel, but it seems to lack any "use offline/online" option, only the "sharing on network" one is present and the trick on that one isn't working. The computer is running Mac OSX 10.9.2)
SOURCE: Invalid printer catridge reading
Doing what the said shouldnt really make any difference it just wont display the message, with compatible cartridges it usually gives you a warning stating they aint original and you usually have to press accept to continue after each print for it to work,, Sorry cant help anymore John
SOURCE: Samsung CLP-510 Printer not printing...
Some network interfaces have been found to be defective. Try printing from parallel or usb until you can get a replacement network interface.
SOURCE: Samsung CLP-300 printer is not recognized on any
If you have the green light and test prints OK, check the condition of the USB connector in the back of the printer. The pins inside get damaged by being too close to the wall or something like that, broken connections to the logic pcb, You can solder a new connector on if that's the problem, otherwise you may need a new circuit board.
SOURCE: CLP-315 - CLP-315 Laser Printer: Printer says it is online and ready to print. All ...
you may want to run a repair on the printer driver. by going to windows START -> all programs -> Samsung CLP 310 -> Maintenece - > repair and follow the onscreen next till finish.
this could help some time when you swap USB cable or port or PCA main been replace or updated.
SOURCE: Hello. My husband and
Hi Dina,
Is the printer directly connected to your husband's computer?
If so your husband's computer MUST be switched on AND connected to the network. Depending on your settings your husband's computer may have to be logged in, for it to be 'connected to the network'
Also power saving could be causing you problems. I.e. your husbands machine may be going into 'sleep' mode when not in use. You can adjust the 'power saving' options from control panel (on your husband's machine) to prevent the computer going off-network and therefore setting your printer 'off-line'
Hope this helps.
Please take the time to rate this answer. Many Thanks Don.
