Pride Mobility Products GoGo Elite Traveller 4 Wheel Travel Scooter Logo
Angel Wheller Posted on Apr 01, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can I stop the beeping noise when going in reverse
I have undone the control panel but there are lots of different wires
Paul Coles
Level 1:
Problem Solver:
  • Contributor 18 Answers
  • Posted on Apr 09, 2015
Paul Coles
Contributor
Level 1:
Problem Solver:
Answers
18
Questions
0
Helped
12231
Points
30
The beeper also provides error codes so not a good idea to start cutting wires .this can be turned off if not required .
this is a 5 minuet job ,but need to be done by a mobility center
who will plug a pp1a/b penny and giles programmer into the 4 pin plug from the sdrive controller select the beep and turn it off ,there is no other way of doing this correctly
ka4iup
Level 3:
  • Master 4,062 Answers
  • Posted on Apr 01, 2015
ka4iup
Master
Level 3:
Answers
4062
Questions
0
Helped
1095772
Points
51404
Find the buzzer and disconnect wires from there, or cut one or both of the wires at the buzzer and tape the connection to prevent shorting.
My Samsung fridge freezer keeps beeping even when doors closed beeps about 10 times stops for a bit then beeps again why and how do I fix this
YEA!!! I have a Samsung refrigerator model number "rs263tdbp/xaa." I fixed the beeping on my refrigerator out of sheer desperation and the total annoyance of it. Mine beeped 11 times which I learned was the door issue. But even with 1. No door open, 2. magnets out, 3. two wires cut.... it was still beeping and it was so I annoying.
I asked the guy at the place I purchased the refrigerator and he said it has a door alarm and if I could find someone to silence the alarm by poking it with something or taking it apart then the fridge would still work. I am the someone in my house. I pin pointed the sound to the back panel. I took off the back panel and placed my ear close to the noise. When I got to this certain part it make my ear ring inside. I believed that to be the alarm. I was like I am either buying a new refrigerator or this noise is about to stop. I pulled the thing out, WITH THE POWER OFF OF COURSE. When I plugged it back in the beeping had stopped and the refrigerator works perfectly. I can only describe this to you because I am not certified in any way. I just stopped my noise on my refrigerator. If you have a different model number yours may be different.
If you take off the back cover (which there is a warning against!!!) Anyway... if you take off the back cover you will see two different boards with a lot of electrical stuff on it. It is the control boards. The top one is green and small. The bottom one is light brown, larger and also has a lot more things on it. The alarm is easy to find (to me) If you face the control panels and look at the bottom panel... the light brown larger one. In the middle of the panel board is a hole. Sticking through the hole is a white or beige plastic part of the control panel housing. It is probably about 2 inches long. To the left of this plastic piece sticking out are three very small black pieces lined horizontally. Under the three black pieces is the alarm. I pulled it out with pliers. This black piece is oval with one flat side. The flat side is closest to the control panel. When I pulled it out, I was like "either no sound or no refrigerator" I plugged it back in and the compressor came on. I was happy about that. I put a tray of water in the freezer and a can of soda in the fridge. The next morning I checked and the water was ice and the soda was cold and refreshing. My refrigerator works perfectly now, without the 11 beeps. I am not certified and I am not responsible if you try this and yours does not work. Good luck.
Hey my Samsung cooltech plus is making beeping noises fridge temperature is jumping from one temperature to another while the beeping noise is going on. Can anyone please help me thank you
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :
http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
http://www.appliancerepair.net/refrigerator-repair-1.html
Refrigeration System Basics Chapter 1 Cause of Beeping Noise in Frigidaire Refrigerator eHow
Hi, I have a kenmore elite deep chest freezer. Model 253.16582105. can't stop the beeping, even after replacing the 9 volt battery.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Fridge keeps beeping, have unplugged, checked door and drawer seals and still keeps beeping
http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator. Cause of Beeping Noise in Frigidaire Refrigerator eHow
Model E402b. Why is the alarm going off?
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Cause of Beeping Noise in Frigidaire Refrigerator eHow Cause of Beeping Noise in Frigidaire Refrigerator eHow
Smeg refrigirator keeps beeping without stop
Flap won't stop humming buzzing
How do I get my refrigerator to stop beeping
Beeping noise from oven - won't stop
Try going to the fuse panel and shutting the breaker off to the oven for about 15 minutes. Hopefully the EOC ( electronic oven control ) will reset it self and you will be good to go.
Apr 03, 2010 • Ovens
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
