Naomi Pascoe Posted on Apr 01, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lanier printer spc240dn engine menu nsequence
I have a lanier spc240dn and it was having thermal prob sc542. this has now been fixed but i cant access the service menu to reset the code. The printer doesn't have a keypad it only has stop/start, job reset, menu, escape, up arrow and down arrow.
Bernie Corrigan
Level 3:
Master:
  • Master 487 Answers
  • Posted on Apr 01, 2015
Bernie Corrigan
Master
Level 3:
Master:
Answers
487
Questions
Helped
130488
Points
1204
Go to the Lanier web site and download the manual. If you can't find them then contact them through the site and ask for help. See: http://www.lanier.com/downloads/Default.aspx?hbn=manuals
3answers
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Sc542 error on lanier
That is a dirty thermistor in the fusing unit.
Incorrect toner
defective toner... take it back to your vendor
1helpful
How do I reset a Lanier 226CN Printer with an error code: SC542
In order to clear error SC542, you can perform the following:
Press and hold online + escape, then power on.
Use up and down arrow keys to select SP2
Press Enter
Use up and down arrow to locate SP5
Press Enter
Use up and down arrow keys to select 810
Press Enter
Confirm the selection
Power off and on.
Please let us know if this works for you.
Also, check all of the connectors on the fuser connector and receptacle, just to make sure that full contact is being made. read this TSB on updating the thermistors: TSB_106 SC555_SC545_SC542 Occurs.pdf (need to register to views).
Hope helps.
5helpful
Lanier model 5627 with fault code sc542 upon power up.
LOL I think I already gave you a solution try this:
1. Press the clear mode key (yellow key)
2. Use the keypad to enter "107"
3. Old down clear/stop for at least 3 secunds. (red key)
4. Enter the service mode.
5. Exit all the way and turn off.
6. Turn ON
And thats it
Lanier model 5627,fault code SC542 upon power up
try this:
6. Turn ON
And thats it
4helpful
Lanier 5645 has a sc542 error code
this is a problem with the thermistors and will need a technician to come out and fix it for you, the part #'s are aw100052 and aw100053 for the thermistors but you have to enter service mode to clear and reset the code.
if this answers your query please rate my answer accordingly
Regards
1helpful
Lanier LD245 error code SC542 appears
Fuser warm up error. Code can only be reset in service mode after the problem is fixed
Top Lanier Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
