The answer to your question is no, The BMC controlled directly by the BMC are.
1. Power door lock system
2. Remote keyless entry system
3. Power window system
4. Sunroof
5. Interior room lamp
6. Warning chime
7. Turn signal and hazard warning lamps
Configuration EKS00777
DESCRIPTION
U1000
CONFIGURATION has two functions as follows:
? READ CONFIGURATION is the function to confirm vehicle configuration of current BCM.
? WRITE CONFIGURATION is the function to write vehicle configuration on BCM.
CAUTION:
? When replacing BCM, you must perform WRITE CONFIGURATION with CONSULT-II.
? Complete the procedure of WRITE CONFIGURATION in order.
? If you set incorrect WRITE CONFIGURATION, incidents will occur.
? Configuration is different for each vehicle model. Confirm configuration of each vehicle model.
READ CONFIGURATION PROCEDURE
CAUTION:
If CONSULT-II is used with no connection of CONSULT-II CONVERTER, malfunctions might be
detected in self-diagnosis depending on control unit which carries out CAN communication.
This came right out of the 2004 titan manual don't think it's the answer you wanted to hear.
SOURCE: replace control panel on 2004 nissan quest
there is a c-clip you need a small screwdriver to pull it out then gearshift knob will pull off
SOURCE: 2004 Nissan would not start
Try checking your battery and or starter. If not them you might have another electrical problem.
SOURCE: 1997 nissan altima has no spark at the plugs.
get those sensors connected to the output of the module tested cause its ruining the module
SOURCE: code p0455 evap emission (large)
have the gas cap tested or just replace it, then disconnect the battery for 5 minutes to reset the code, then drive it for a few miles and see if problem comes back, if it does a trip to the dealer is in order, as this may be covered by your emission warranty which is good for 70,000 miles.
SOURCE: how do i remove the inside panel of a nissan titan door
Get a 18V drill with phillips screw extention and start buzzing the screws in the armrest and under out...the glass could be anywhere so wear gloves.
Good Luck
